barranquilla Posted October 19, 2011 Report Share Posted October 19, 2011 Will cpi inframes work well on a NOT ported 4mm long rod crank, vforce 3, .50 oversize pistons, and timing plate, stage 2 jets. What timing would you use on the timeing plate? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 19, 2011 Report Share Posted October 19, 2011 Will cpi inframes work well on a NOT ported 4mm long rod crank, vforce 3, .50 oversize pistons, and timing plate, stage 2 jets. What timing would you use on the timeing plate? They will work. T5's might actually be better on a non ported machine. I would get CPI's if you plan on porting and just need to buy new pipes now. If you plan on staying non ported then I would probably get a more traditional pipe. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted October 20, 2011 Report Share Posted October 20, 2011 Will cpi inframes work well on a NOT ported 4mm long rod crank, vforce 3, .50 oversize pistons, and timing plate, stage 2 jets. What timing would you use on the timeing plate? 2 posts 2 hours apart......all about the same thing. gonna let it go easy this time....haha.... Quote Link to comment Share on other sites More sharing options...
