cpi stingers/silencers inside frame
werner
Explain to me how you relocate cpi stingers to inside the frame under the seat instead of either side outside the frame.
Has to do with cutting stingers or is there rewelding involved?
i think it is as simple as swapping the stingers side to side on the cpi's.
I think you also have to switch silence body sides too. You also need change the clock position of the rear silencer plate. So you will have to drill 3 new holes and re tap them. Maybe some one with experiance will chime up. I it might have been JDS who use to make a silencer braket as well.
