Screamin_Banshee Posted November 13, 2011 Report Share Posted November 13, 2011 Thanks for the advice. I'll try adjusting the shock set up first to get that back end down. The two banshees I was losing to had stut set ups and were hooking instantly. They were 200 lb riders with the same gearing and same tires. I was losing by 1 to 2 bike lengths and my trap speed was 4mph faster. If I could get this to launch I'm set. Sounds like you talked a bit with these guys. Since they were hooking up better than you, why not try a similar set-up? Its atleast a starting point. I think at 150lbs, the +10, w a bar might be much. But then again, every rider, and track is different. Yea it is. If you could run 4.6 with a 350cc banshee you will win. Could be done. Ive done it in sand. 350, 2-5 override, methanol (stocker) carbs, +6 w a bar, 22" ultralight haulers blah blah blah...but that was long ago. Quote Link to comment Share on other sites More sharing options...
