+10 swing arm killing my traction. what length should i go to?
BuckeyeShee21
Thanks for the advice. I'll try adjusting the shock set up first to get that back end down. The two banshees I was losing to had stut set ups and were hooking instantly. They were 200 lb riders with the same gearing and same tires. I was losing by 1 to 2 bike lengths and my trap speed was 4mph faster. If I could get this to launch I'm set.
Sounds like you talked a bit with these guys. Since they were hooking up better than you, why not try a similar set-up? Its atleast a starting point.
I think at 150lbs, the +10, w a bar might be much. But then again, every rider, and track is different.
Yea it is. If you could run 4.6 with a 350cc banshee you will win.
Could be done. Ive done it in sand.
350, 2-5 override, methanol (stocker) carbs, +6 w a bar, 22" ultralight haulers blah blah blah...but that was long ago.
