moledigger Posted October 11, 2011 Report Share Posted October 11, 2011 This is after riding for awhile. Quote Link to comment Share on other sites More sharing options...
gotta_goatsfast Posted October 11, 2011 Report Share Posted October 11, 2011 Hard to see any detail but the real dark porcelain insulator with a thick black ring indicates super rich. Your porcelain should not be colored much and there should be a 2mm chocolate or cardboard brown ring around the base. What is the current specs and jetting? Quote Link to comment Share on other sites More sharing options...
moledigger Posted October 12, 2011 Author Report Share Posted October 12, 2011 Hard to see any detail but the real dark porcelain insulator with a thick black ring indicates super rich. Your porcelain should not be colored much and there should be a 2mm chocolate or cardboard brown ring around the base. What is the current specs and jetting? 27.5 280 needle in middle I am running vf3's and +4 timing. Motor is stock bored 64.50 and a set of DMC 916's. Power seams good 1-3 then in 4th it hits a like standstill then all of the sudden picks up. Doesn't feel like a bog, more like a hold in the rpm then jumps up. Just add 3 hd spring to the clutch so i dont think its slipping. Quote Link to comment Share on other sites More sharing options...
Zwiser Posted October 12, 2011 Report Share Posted October 12, 2011 Hard to see any detail but the real dark porcelain insulator with a thick black ring indicates super rich. Your porcelain should not be colored much and there should be a 2mm chocolate or cardboard brown ring around the base. What is the current specs and jetting? sorry for jacking the thread but by this do you mean a nice colored ring at the base and the rest white? because i have a nice base ring then its white and a light tan up top Quote Link to comment Share on other sites More sharing options...
volcrano Posted October 12, 2011 Report Share Posted October 12, 2011 http://www.dfn.com/agservices/plugchop.html Quote Link to comment Share on other sites More sharing options...
Zwiser Posted October 12, 2011 Report Share Posted October 12, 2011 thanks! Quote Link to comment Share on other sites More sharing options...
