One side leaner?
Zwiser
Hello, the right side cylinders plug is "off" white on the tip with a light yellow in front of the tip, and the left sides plug is a chocolate milk color with a dark brown spot in front of the tip.
same jets (48 pilots, 148 mains) floats set at 19mm, JJH needles 3rd clip, the packing on the left side is fiberglass and probably needs replaced, and the right side is packed (loosely) with 6 S.O.S pads, the right side compression is 155 and the left is 157.
also i was looking at the fuel lines and the left carbs is more angled than the right, could this cause the left to get more fuel than the right and leaning the right side out? its hard to make the fuel line more equate because the inlets are both on the right side on the pwk 28s.
please help im going for a big riding trip this weekend and id like to eliminate some possible problems, Thanks!
  • 2 months later...
