94Mike Posted October 5, 2011 Report Share Posted October 5, 2011 Can you guys with servals still go for some longish rides or is the consumption bad, for gas btw. Thanks, Mike Quote Link to comment Share on other sites More sharing options...
lms1977 Posted October 5, 2011 Report Share Posted October 5, 2011 Mine is a gas hog 10mil serval but I put a bigger tank on it, it probably uses 1.5 to 2 times the gas as my old ported stocker Quote Link to comment Share on other sites More sharing options...
94Mike Posted October 5, 2011 Author Report Share Posted October 5, 2011 Mine is a gas hog 10mil serval but I put a bigger tank on it, it probably uses 1.5 to 2 times the gas as my old ported stocker What about a 4 mil? Or is there not that much of a difference. Quote Link to comment Share on other sites More sharing options...
CFH87 Posted October 6, 2011 Report Share Posted October 6, 2011 This all depends on carbs and what cc motor you have... A bigger motor is gunna need more fuel my 350 dune port does just fine only have 3 sizes bigger mains in it. Not much a diff in fuel but deff a diff power... Quote Link to comment Share on other sites More sharing options...
94Mike Posted October 6, 2011 Author Report Share Posted October 6, 2011 This all depends on carbs and what cc motor you have... A bigger motor is gunna need more fuel my 350 dune port does just fine only have 3 sizes bigger mains in it. Not much a diff in fuel but deff a diff power... Thanks CFH, but im interested in a 421 serval gas consumption. Quote Link to comment Share on other sites More sharing options...
gotta_goatsfast Posted October 6, 2011 Report Share Posted October 6, 2011 With my setup listed in the sig I burn through my 5.5gal tank in 2-2.5 hours. I'm always in the powerband, however. Not sure what improvement would be seen if trail riding for instance. Banshees are thirsty, I would expect a stock tank to last no more than 90 minutes of aggressive riding. Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted October 6, 2011 Report Share Posted October 6, 2011 I have a 421 serval with 35mm a/s and running R2 pipes. When I took it out this last time trail riding I got a good 3-4 hours out of a tank of gas( stock size). And I'm by no means light on the go peddle. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted October 6, 2011 Report Share Posted October 6, 2011 1.5-2 hours for me on a 4mm with stock tank. Quote Link to comment Share on other sites More sharing options...
lms1977 Posted October 6, 2011 Report Share Posted October 6, 2011 (edited) I have a 421 serval with 35mm a/s and running R2 pipes. When I took it out this last time trail riding I got a good 3-4 hours out of a tank of gas( stock size). And I'm by no means light on the go peddle. wow that's more than I got with the ported stock motor running it hard Edited October 6, 2011 by lms1977 Quote Link to comment Share on other sites More sharing options...
94Mike Posted October 6, 2011 Author Report Share Posted October 6, 2011 Thanks guys looking forward till i eventually get one. What tanks you guys run? Is there any bigger tank that doesnt look silly or do they all do... . Quote Link to comment Share on other sites More sharing options...
lms1977 Posted October 6, 2011 Report Share Posted October 6, 2011 I think the Clark looks a little better, I have never been real worried about what it looks like I just like to ride and not worry about running out of fuel!!!! Quote Link to comment Share on other sites More sharing options...
decon Posted October 6, 2011 Report Share Posted October 6, 2011 You could get the IMS 4 gallon tank. It doesn't look as bulky as the 5 gallon, the only downside is it doesn't hold as much fuel. It's either better looks or better MPG, choose one. However, if you dont like the looks of the clarke/ims tank you can gain a little more fuel capacity with the stock tank. It's not much but every bit counts. Drain your gas from your tank and disconnect your fuel lines from your carbs. Boil some hot water and fill up your tank while it's still bolted on the frame. Close your gas cap and take an air compressor or a hand pump to your vent hose, fill it with a little air but not too much. Let it sit for a few minutes while it's still filled with air. The boiling water will make the plastic tank soft, and the compressed air will expand it. Let it cool down, then repeat. I gained maybe a quart or two of extra fuel. Im just suprised no company has yet to make a stealthy gas tank to fit under the stock plastics that holds extra fuel, I wonder would it be hard for someone to do? Quote Link to comment Share on other sites More sharing options...
94Mike Posted October 6, 2011 Author Report Share Posted October 6, 2011 Thanks guys, its not the look of the quad im worried about, its the headache im going to get FROM looking at it . Ill prob start looking at the 4 gallon tank, Im not sure how much the stock tank holds is it 3.0 or 3.5? Quote Link to comment Share on other sites More sharing options...
coryv4 Posted October 6, 2011 Report Share Posted October 6, 2011 on gas with stock carbs i got about 2-3 hours of hard riding now i get about an hour..............lol Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted October 7, 2011 Report Share Posted October 7, 2011 Coryv what carbs did you go to that's making you get an hour on a tank. Quote Link to comment Share on other sites More sharing options...
