4 mil stroker build
Do I need special gaskets? Im buying 4 mil ported cylinders and cool head of ride race live. Im thinking im going to buy different domes. What compression should i shoot for. I know i need domes cut for a 4 mil but i want to know more before i order the domes. Thanks guys.
no you wont need special gaskets. Just special cut domes for the stroke and the regular gaskets
My head takes the extended head studs and you can use the copper washers and o ring kit they offer for the other heads.
for pump gas a good solid comp is 145 150ish depending what type of terrain your riding in
Im going to b doing trails. Are you sending me the washers with the cyls and head i bought from you. Did you check and see that i sent you payment?
Pretty much need the following.
4mill crank
Cylinder head with cut stroker domes, or a custom cut stock head. Cylinder spacer will work but it also alters the port timing since it raises the cylinders hight.
If your running a long rod 4mill crank you will need 795 series pistons. This is for the longer rod, and is required for both a stock stroke long rod or a 4mill long rod crank.
