lowbuckracing Posted October 5, 2011 Report Share Posted October 5, 2011 Check to see if the woodruff key is worn out or missing.. Quote Link to comment Share on other sites More sharing options...
Dicklez Posted October 5, 2011 Report Share Posted October 5, 2011 Pistons in the right way? Arrow towards the exhaust? Quote Link to comment Share on other sites More sharing options...
SheeRida Posted October 5, 2011 Author Report Share Posted October 5, 2011 yes the key is in. the pistons are in correctly. the tors is removed and unpluggd. coil gap is correct. carbs are adjusted correctly all jets are correct. compression is at 120 psi. choke tube is in place. i mean this thing will start up and idle fine. if i touch the throttle it will die. then its a little hard to start. but it will sit there and idle as long as it wants. i did remove the parking brake cable. do i need to ground something? it has spark so i figured everythin is good to go. Quote Link to comment Share on other sites More sharing options...
