carlson.banshee Posted September 28, 2011 Report Share Posted September 28, 2011 hey guys i have a 2000 banshee that i recentally took the motor out to split the case to replace a welded clutch rod....after putting it back together it starts right up and idles perfect but has no throttle responce it just wants to die when you throttle up i have aftermarket mikuni carbs with 180 mains with no t.o.r.s. it ran perfect before i dont get any ideas anyone Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted September 28, 2011 Report Share Posted September 28, 2011 If you have adjustable timing plate make sure it is +4 not-4. Set pick-up coil gap. Make sure ground is clean and tite, check ground for coil, check all connections areclean. Are carbs clean? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted September 28, 2011 Report Share Posted September 28, 2011 How was the PB Rev Limiter eliminated? Is it possible the wire is still there and shorted to ground? Quote Link to comment Share on other sites More sharing options...
