trans problems
So i was out riding this weekend an my banshee is having tranny problems.
I shifted in to 3rd gear an then when i went to go shift again my shifter was stuck down an it wouldnt move.
then when i stopped an tried to shift it would shift but i had to pull it up way high an it was really hard to shift
i got it to shift up and down but i have to push it WAY down or pull it WAY up for it to even budge into the next gear
does anyone know what it could be??
thanks, any suggestions help
pull the clutch cover off, and check out the shift arm spring and adjustment bolt. check the shift star lever spring too. you might have to pull the clutch basket off to fully see the star and the selector.
okay i will do that today thanks
does anyone have a link where i could get a service manual for free??
this is one of the most common repairs i do here.
you need:
shift shaft, plastic spacer, spring, alignment pin, lock washer and lock nut, also a clutch cover gasket and 2 qts of bottom end fluid and some coolant.
replace ALL of it or you will have a problem again.
Cam will this fix this problem? Reason I ask is that I have the same problem on mine too. I have a HJR 4mil and I have difficulty with 4 5 and 6. 1-3 shifts great. I was going to tear it apart and do a cut transmission. I can't really use an override since I xc/woods ride and would be back loading a lot. If this would fix my issue I'd much rather go this route.
