lms1977 Posted September 20, 2011 Report Share Posted September 20, 2011 I have a 465 serval with 35mm pwk shearer sb inframes 165lb comp run race fuel in it now need to put my other domes in. I always ran a airbox everyone is telling me to ditch it and get pods, what I want to know has anyone ever run a airbox with a 421 or bigger cub or something better than 70-80 hp then switched to pods what will I gain? I run no lid a k&n with a foam outer wear and it rips hard as hell. if it will only give me a tiny bit more top end I'm not sure I even want to play with it. but if it will run better all over then it would be worth trying. I do run in mud water snow dirt dust coal and rocks but I'm sure I can fab a shield for wet days and I'll just have to be careful Any help would be great thanks Mike Quote Link to comment Share on other sites More sharing options...
guns4children Posted September 20, 2011 Report Share Posted September 20, 2011 I can't tell you about performance gains but I can tell you I put pods on my bike and hated it. I did my best to avoid puddles but it wasn't enough. I would hit water then spend the next 5 minutes bogging till they dried out. I used them 2 trips and couldn't take it any more. Here's my attempt at a shield. (I don't have access to a welder) Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted September 20, 2011 Report Share Posted September 20, 2011 Pods are a no go if water and mud is involved. I have a 421 serval on it's way and I'm going to be running open lid box, not pods Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted September 21, 2011 Report Share Posted September 21, 2011 Is it a 7mill? You running an overide? Quote Link to comment Share on other sites More sharing options...
lms1977 Posted September 21, 2011 Author Report Share Posted September 21, 2011 It's a 10mil and no over ride just modified gears to make it shift for now. Yea the muddy filters is what I'm worried about. Would really like to know the performance difference!! Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 21, 2011 Report Share Posted September 21, 2011 Well LMS....... I would definitely say go ahead and try to fab somethin up like a shroud if you do swap to pods. But in my experience, I went from pods to the big ass K&N with a pro flow kit and never felt a difference. Jetted the exact same and dynoed the same. The key is to keep the filter and pre filter as clean as possible and there should be no problem. Facts go as is, Pods are super easy to contend with. The box......... NOT! Just keep the box around for disgusting rides. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted September 21, 2011 Report Share Posted September 21, 2011 Why not write down your keying right now so you can always switch back to the box and not have to plug chop........AND buy a set of pods and find the jetting for that? Then you get both worlds with the ease of swapping..... Quote Link to comment Share on other sites More sharing options...
lms1977 Posted September 21, 2011 Author Report Share Posted September 21, 2011 Trickedcarbine What was all done to yours what kind of power were you making? I always keep filters clean and always take a spare.!!! Quote Link to comment Share on other sites More sharing options...
lms1977 Posted September 23, 2011 Author Report Share Posted September 23, 2011 so nobody has done the switch from airbox to pods with a fairly high hp bike? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 23, 2011 Report Share Posted September 23, 2011 Trickedcarbine What was all done to yours what kind of power were you making? I always keep filters clean and always take a spare.!!! The motor was almost identical to my signature motor. Just different head, still on race gas. Makes 80 on pods, and makes 80 with an open box with the pro flow kit. That filter in the pro flow kit is big as fuck! It didn't choke me down at all. Maybe...... just maybe it might hold your big 10 mil back a horse or two, but it's better then hitting a puddle and hydro- locking your motor. I speak from experience on that. Pods on a little open ice turned my old crank rods in to "Z" shaped scrap! Quote Link to comment Share on other sites More sharing options...
lms1977 Posted September 24, 2011 Author Report Share Posted September 24, 2011 wow surprised the results were the same thank you for getting back to me Quote Link to comment Share on other sites More sharing options...
