Ive decided that I want an airbox on my bike.. when I bought it, the stock one had already been removed.. has anyone ever seen or used this???
http://cgi.ebay.com/ebaymotors/Yamaha-Banshee-CFM-Aluminum-Airbox-Air-Box-Intake-New-/380363822182?pt=Motors_ATV_Parts_Accessories&hash=item588f735466#ht_533wt_1165
and would you recommend this? if not, what route would yall take on installing an airbox.
I wouldn't buy one of those. I'm sure someone around here has a stocker with a pro-flow adapter for sale cheap. 90 bucks, plus you still have to spend another $50+ for the filters. Not to mention the filters you have to use are tiny. In my opinion, they can't flow nearly as well as the pro-flow setup.
You can expect a 6HP increase on a stock Banshee and up to 10HP on a modified machine.
:shrugani:
Yet another reason to not buy from them.
  • 2 weeks later...
Fluid dynamics! When a fluid is forced from an orfice by means of pressure, it is directed in one path. However, when there is a vacuum or less pressure in which molecules move in to fill that void, they are drawn from any and all direction. This is why the front of the carb is shaped like a bell. Pod filters help the carb pull more air in because it is allowed to draw air in through a broader range of direction than what would be allowed by a length of tube. In short, yes you will lose some giddy-up.
Shut up Lard Boy... There shouldn't be any arguments with that response... lol
