SuperMex Posted September 14, 2011 Report Share Posted September 14, 2011 What is involved in modding the shift shaft? I have searched but all i find is Shift Star mod. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 14, 2011 Report Share Posted September 14, 2011 What is involved in modding the shift shaft? I have searched but all i find is Shift Star mod. The mod i've used is opening up the slot where the adjustment cam/bolt goes. It just allows more travel. .......now is there another mod i'm unaware of? If so, i'd like to find out about it. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted September 14, 2011 Report Share Posted September 14, 2011 http://www.farmandsandtoys.com/partdetail.asp?partid=132 Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted September 14, 2011 Report Share Posted September 14, 2011 http://www.farmandsandtoys.com/partdetail.asp?partid=132 THANK YOU! I must be half retarded because i have been looking for that modded shift shaft on site sponsors with no luck for a while now. Ill be ordering that next week to go with the shift star i have already. Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted September 15, 2011 Report Share Posted September 15, 2011 Yes the slot is opened like mentioned above and the shaft spring is lighter. Quote Link to comment Share on other sites More sharing options...
spurdy Posted September 15, 2011 Report Share Posted September 15, 2011 Yes the slot is opened like mentioned above and the shaft spring is lighter. Yep, You can also bore the holes out in the case half that the shaft goes through and install a needle bearing. You can also turn down the shaft drum on the primary drive side and install a needle bearing there. That puts the drum rotating on two bearinsg, one on each side instead of only one side. Together you can make a stock transmission shift pretty damn nicely. SP Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted September 15, 2011 Report Share Posted September 15, 2011 The needle bearings in the holes for the shift shaft sound good. The drum mod also sounds good. Do you know of any shops that offer these services? Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted September 15, 2011 Report Share Posted September 15, 2011 my tranny shifts like no other.. its unreal here is whats done to it new modded shift shaft, cut star, modded drum with bearing on end, shift pro arm with easy spring from FAST, every other dog on the gears removed.. Quote Link to comment Share on other sites More sharing options...
spurdy Posted September 15, 2011 Report Share Posted September 15, 2011 The needle bearings in the holes for the shift shaft sound good. The drum mod also sounds good. Do you know of any shops that offer these services? I've done mine myself. If your handy with a drill it is no problem to enlare the hole in the case for the shift shaft bearings. A drill press would be the easiest. Adding the bearing to the drum requires the use of a lathe. I am not sure if Andy at M&M offers this service but I would bet he could do it considering everything else he does. my tranny shifts like no other.. its unreal here is whats done to it new modded shift shaft, cut star, modded drum with bearing on end, shift pro arm with easy spring from FAST, every other dog on the gears removed.. That is exactly whats been done to my last transmission. Along with the bearings on the shift shaft, and every other webbing cut out on the gears mating to the gears with the dogs. Shifts like butter without the use of the clutch. Cannot shift under wide open throttle like an over ride but the next best thing IMO. I think Kevin at HJR was cutting gears this way for guys. I've done mine on a mill at work but the gears are pretty hard and it is slow going for sure. SP Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted September 15, 2011 Report Share Posted September 15, 2011 It seems that a lot of people advocate cutting every other dog and engagement dog to their gears. Do Duneable Overrides have this done to them in conjunction to whatever else makes them shift when WFO? Does anyone know if a Duneable N-1-6 is available? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted September 15, 2011 Report Share Posted September 15, 2011 modded shaft. Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted September 15, 2011 Report Share Posted September 15, 2011 (edited) Yep, perfect pic! But IIRC, F.A.S.T. mods both sides, but I may be mistaken. F.A.S.T. also includes a slightly softer spring as well. Edited September 15, 2011 by Strm Trpr Quote Link to comment Share on other sites More sharing options...
spurdy Posted September 16, 2011 Report Share Posted September 16, 2011 It seems that a lot of people advocate cutting every other dog and engagement dog to their gears. Do Duneable Overrides have this done to them in conjunction to whatever else makes them shift when WFO? Does anyone know if a Duneable N-1-6 is available? Yes, all the overrides I have seen have that done also, in addition to springs on the shift fork shafts and modificatin to the shift drum path for the shifting forks. Don't think I have ever seen a N down 1-6. SP Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted September 16, 2011 Report Share Posted September 16, 2011 Here is a pic of the mod to the shift shaft on my shee. I have a Mull mod shift star, mod shift shaft, shift pro arm & spring. She shift like great. On the next rebuild I would like to do the bearing upgrades. Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted September 17, 2011 Report Share Posted September 17, 2011 Yep, You can also bore the holes out in the case half that the shaft goes through and install a needle bearing. You can also turn down the shaft drum on the primary drive side and install a needle bearing there. That puts the drum rotating on two bearinsg, one on each side instead of only one side. Together you can make a stock transmission shift pretty damn nicely. SP Do you know where to get the needle bearings for the shift shaft at? My cases are split right now and I'd like to look in to that Quote Link to comment Share on other sites More sharing options...
