okbeast Posted September 13, 2011 Report Share Posted September 13, 2011 Did you test what the positive and negative leads coming off the reg/rec were putting out? I just added a Trailtech reg/rec to my 250r and when I measure the leads when they are disconnected from the battery they are only putting out .7 volts. RPM didn't seem to matter any either. I was just wondering if hte reg/rec has to be hooked up to the battery to put out the correct 12 volts or what... Quote Link to comment Share on other sites More sharing options...
Coupelx Posted September 13, 2011 Report Share Posted September 13, 2011 Did you test what the positive and negative leads coming off the reg/rec were putting out? I just added a Trailtech reg/rec to my 250r and when I measure the leads when they are disconnected from the battery they are only putting out .7 volts. RPM didn't seem to matter any either. I was just wondering if hte reg/rec has to be hooked up to the battery to put out the correct 12 volts or what... i dont know anything about the 250r's but on a banshee you need to float the ground on the stator. providing that is done, there should be a load such as a battery on the regulator and it is possible to fry one otherwise. found that out the hard way. hook the battery up and test voltage with the bike off and again with it running and compare. Quote Link to comment Share on other sites More sharing options...
okbeast Posted September 13, 2011 Author Report Share Posted September 13, 2011 i dont know anything about the 250r's but on a banshee you need to float the ground on the stator. providing that is done, there should be a load such as a battery on the regulator and it is possible to fry one otherwise. found that out the hard way. hook the battery up and test voltage with the bike off and again with it running and compare. Well shit. I tested the reg/rec with it unhooked from the battery. Didn't really think about it being a bad thing. I'm gonna be awfully pissed if this screwed it up. Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted September 13, 2011 Report Share Posted September 13, 2011 Along the same line, anyone have any pictures of the best place to mount a battery? What type of battery is the best to use in this application? Thanks, Wheat Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted September 13, 2011 Report Share Posted September 13, 2011 I mounted mine where the header tank was off of some L shaped brackets, I've got a Ktm battery in a Ktm 450 battery holder. The holder only cost me the equivalent of about $10 with the rubber to keep the battery locked in place, I've also seen people mount them behind the bumper. Quote Link to comment Share on other sites More sharing options...
camatv Posted September 13, 2011 Report Share Posted September 13, 2011 my battery is in the plastic in the spot where the tools were its cut out and has a cheese ball plastic mount in there. it works someday i might fix it.. i have a bad ass stainless steel battery box i'd sell it was made for a YFZ but should be able to be used on anything with a lil ingenuity Quote Link to comment Share on other sites More sharing options...
okbeast Posted September 13, 2011 Author Report Share Posted September 13, 2011 my battery is in the plastic in the spot where the tools were its cut out and has a cheese ball plastic mount in there. it works someday i might fix it.. i have a bad ass stainless steel battery box i'd sell it was made for a YFZ but should be able to be used on anything with a lil ingenuity This is on a 250r and the airbox on it would have been a good place but I put a K&N on it the first day. The battery is charging at 14 volts with the bike running, so I'd say I'm good to go. Quote Link to comment Share on other sites More sharing options...
