I'm officially an idiot
Coolhand
So, yesterday, I finally get my engine back together after a new crank and pistons. And I got so excited to start it, plus I was drinking, I fired it up with no trans oil in the crank case. It ran sweet until it started making a weird noise and wanting to engage in neutral. The bike only ran for literally 10 seconds before I realized how damn stupid I am and shut her down. Can 10 seconds running in neutral dry fry bearings?
:shootself:
Fill it COMPLETELY full with ATF rock it around to get the air out of it and let it sit for some amount of time and let the oil work into everything. Then drain down to normal level and ride it around for a bit. Then empty and and refill with clean. If its fucked then its fucked no matter what but Id give this a try before you call it junk.
I filled her up with gear saver and did just about everything you guys said. It started fine and ran for about 10 seconds again...then made the same noise and started trying to engage in neutral. I shut it off right away cause I'm a pussy. But then decided to grow some nuts and just let it idle. I let it run for a couple minutes with the noise and it got a little worse, then completely stopped. Man, I'm so stoked that I'm not a complete fuck up.
Thanks everybody for the advice.
