chetgoff Posted September 5, 2011 Report Share Posted September 5, 2011 anybody ever done this? Quote Link to comment Share on other sites More sharing options...
NYUK Posted September 5, 2011 Report Share Posted September 5, 2011 just buy a new gear. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted September 5, 2011 Report Share Posted September 5, 2011 Then why woul FAST sell steel bushings? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 5, 2011 Report Share Posted September 5, 2011 Just use a socket that's about the same size as the bushing. Drive it out in a vice. Then press the new one in. It takes about 3 minutes to do it and then it's like brand new. I recommend replacing that bushing every year. For no more than it costs it's worth it when you consider the damage it can do if the clip and washer comes off because the gear has slop in it. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 5, 2011 Report Share Posted September 5, 2011 I agree with loco, but with the steel bushing you shouldn't have to replace it so often. If you run the stock one with the bronze bushing, I would replace it any time you have the clutch cover off. (within reason). They are cheap, and so are the washers and clips that hold it on. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted September 6, 2011 Report Share Posted September 6, 2011 Just use a socket that's about the same size as the bushing. Drive it out in a vice. Then press the new one in. It takes about 3 minutes to do it and then it's like brand new. I recommend replacing that bushing every year. For no more than it costs it's worth it when you consider the damage it can do if the clip and washer comes off because the gear has slop in it. Thats exactly how I did mine. Its an easy and cheap fix. Replace as needed Quote Link to comment Share on other sites More sharing options...
chetgoff Posted September 6, 2011 Author Report Share Posted September 6, 2011 thanks for help guy's it came right out now to press in the new one. Quote Link to comment Share on other sites More sharing options...
camatv Posted September 6, 2011 Report Share Posted September 6, 2011 i have a small driver that a friend of mine made works like a charm. Quote Link to comment Share on other sites More sharing options...
spurdy Posted September 7, 2011 Report Share Posted September 7, 2011 i have a small driver that a friend of mine made works like a charm. Don't tell us about cool little tools like that unless you are gonna hook a brotha up with one! SP Quote Link to comment Share on other sites More sharing options...
