DBR06Banshee10 Posted September 4, 2011 Report Share Posted September 4, 2011 Bike Runs Fine Then The Gear Oil Starts Comin Outta The Over FLow Line And Its Thick And White I Just Brought This Bike Last Night And All I Know Is IT Has Drag Parts In THe Motor WIth Pro Circuit Race Pipes With A 18 Front Tooth Sproket. Any Suggestions On How To Fix Tha Problem???? Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted September 4, 2011 Report Share Posted September 4, 2011 You're getting coolant in the gear case. There is a o-ring on the pipe that goes into the clutch cover, that could be bad. Bad water pump seal is another possibility. Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted September 4, 2011 Report Share Posted September 4, 2011 Bike Runs Fine Then The Gear Oil Starts Comin Outta The Over FLow Line And Its Thick And White I Just Brought This Bike Last Night And All I Know Is IT Has Drag Parts In THe Motor WIth Pro Circuit Race Pipes With A 18 Front Tooth Sproket. Any Suggestions On How To Fix Tha Problem???? engine coolant mixing with the oil, stop riding and fix... immediatly... check the waterpump cover and the netral switch all that.... Quote Link to comment Share on other sites More sharing options...
shanYE west Posted September 4, 2011 Report Share Posted September 4, 2011 engine coolant mixing with the oil, stop riding and fix... immediatly... check the waterpump cover and the netral switch all that.... wont be the water pump cover or the N switch. probalby the o-ring on the coolant tube through the case. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 5, 2011 Report Share Posted September 5, 2011 Sounds like time to pull the clutch cover... I have a bottom end walk-through pinned at the top of the repairs and mods section. Take a look at it and you will see how simple the bottom end and clutch side are to work on... - Jared Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted September 6, 2011 Report Share Posted September 6, 2011 You know what i meant! Actually when i did dissemble everything something was leakin from the cracked plastic switch cover. Reolaced it with billet. Quote Link to comment Share on other sites More sharing options...
