blackbansheeboy Posted September 1, 2011 Report Share Posted September 1, 2011 Was hoping that the banshee guys can help me out here. I put new a-arms and shocks on my banshee and bled the brakes... but nothing happened I get plenty of brake fluid out at the brakes but there's no brakes still. Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted September 1, 2011 Report Share Posted September 1, 2011 Make sure everything is tight and there are no leaks whatsoever and keep trying. Keep plenty of fluid handy as well and keep the M/C as full as possible. I'm assuming you're doing it correctly in the first place... Quote Link to comment Share on other sites More sharing options...
Phelps Posted September 1, 2011 Report Share Posted September 1, 2011 you either have to bleed them backwards (from the caliper up with a pump) or just set there and barely tap the brake lever until you see tiny bubbles coming up. doing it that way will take a while! Quote Link to comment Share on other sites More sharing options...
Rotax Raptor Posted September 1, 2011 Report Share Posted September 1, 2011 you either have to bleed them backwards (from the caliper up with a pump) or just set there and barely tap the brake lever until you see tiny bubbles coming up. doing it that way will take a while! You mean fill them backwards with a pump, right? Quote Link to comment Share on other sites More sharing options...
Phelps Posted September 1, 2011 Report Share Posted September 1, 2011 You mean fill them backwards with a pump, right? yes. a hand held pump and force oil through the bleeder valve. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted September 1, 2011 Report Share Posted September 1, 2011 open both bleeders and let gravity do something other than make you fall down when drunk. just keep the reservoir full. if your bleeders are loose in their threads wrapping teflon tape around them helps keep air out. Quote Link to comment Share on other sites More sharing options...
blackbansheeboy Posted September 1, 2011 Author Report Share Posted September 1, 2011 Ive done the reverse pumping and it didn't do anything and ive just sat on the bike and pumped, and all the lines are tight. Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted September 1, 2011 Report Share Posted September 1, 2011 It just takes time and patience. Walk away from it for an hour or 2, then try again. I did that and it worked for me. I agree with the gravity technique as well.... just loosen the bleed screws a bit, fill the reservoir, and walk away for an hour. Then try pump and bleed. Once you get some pressure (U will), you may have to ride the bike a few times, and bleed again in between. tap the calipers and lines and reservoir lightly with the 8mm wrench too. Good Luck, Tim Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 1, 2011 Report Share Posted September 1, 2011 I can bleed front and back brakes in less than 5 minutes. All you need is a Mityvac. They're about $40 from an auto parts store. It's an invaluable tool. Why dick around with gravity bleeding when you can use a pump? Quote Link to comment Share on other sites More sharing options...
blackbansheeboy Posted September 1, 2011 Author Report Share Posted September 1, 2011 Well it has been a couple days since i did bleed the brakes and theres still nothing. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 1, 2011 Report Share Posted September 1, 2011 Buy a Mityvac and be done with it. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted September 1, 2011 Report Share Posted September 1, 2011 gravity saves me $40 for hookers and blow. Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted September 1, 2011 Report Share Posted September 1, 2011 My brake rear brake line is massively long for like a plus 14 and it took maybe five mins to do. Wife was at the back closing and cracking open and i pumped them shot out fluid in like 4 mins. Make sure ur using the right kind of fluid? Maybe ur using something too viscouse Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 1, 2011 Report Share Posted September 1, 2011 gravity saves me $40 for hookers and blow. My therapist said I had to quit those, so I bought a Mityvac. Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted September 2, 2011 Report Share Posted September 2, 2011 I can bleed front and back brakes in less than 5 minutes. All you need is a Mityvac. They're about $40 from an auto parts store. It's an invaluable tool. Why dick around with gravity bleeding when you can use a pump? Sometimes brand new brake lines and hard to get the pressure started. I just installed A Arms and SS lines, and even with my friend's mity vac, it took a while to get the brake lever to build pressure. Ive had this problem on other bikes when going from a dry system as well. Take your 8mm wrench and tap on the calipers, then tap on the lines, then on the master cylinder. Keep pumping the hand brake, open one of the bleed screws for a second, and close right away, keep pumping, and open again for a second. repeat this on both sides. It takes some patience for the stubborn ones. But somehow it just seems to majically build pressure. Mity Vac definately helps. Also taking a break from it for an hour seems to help (even mentions this in the manual). Good luck and keep us posted. Quote Link to comment Share on other sites More sharing options...
