4MiLLDraGSheE Posted August 26, 2011 Report Share Posted August 26, 2011 I dont know much about runnin on alky and dont really have plugs to look at cuz i purged it after i ran it. I will post pics asap. So i have a hjr drag port 4 mill stock cylinder with 39 pwks with power jets. I dont know what theyre set at but i have br8es plugs gapped at .018 amd for the little time i did run it i had fuel coming out the exhaust a little bit. Im assuming im running rich ive been reading up quite a bit recently but dont know how to adjust this stuff. Should i just lean it a touch or just turn down the powerjet? I have v force 3 reeds override tranny if that matters and i live in michigan. Let me know what u think if theyres a better plug out there for me let me know. Quote Link to comment Share on other sites More sharing options...
blackedout96 Posted August 26, 2011 Report Share Posted August 26, 2011 I usually dial mine in with just the pj. I thought br9's were a must with alky but I could be wrong Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted August 26, 2011 Report Share Posted August 26, 2011 You can still check those plugs because you arent looking at brown color, you are looking for the flat base of the plug at the end of the threads and seeing if the nickle plating is burned on the flat part and how much it is burned. You'd like to see some of that plating turned a flat dull gray color and if its rich it wont burn any and if its right a burn mark will start moving half way around the base. Like from 9 to 3 Oclock. Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted August 26, 2011 Author Report Share Posted August 26, 2011 Alright. All i did is heat cycle it though i need to actually run it a lil dont i? I will post pictures of the plugs then when i get home. And ill look for the rings. Quote Link to comment Share on other sites More sharing options...
springer Posted August 26, 2011 Report Share Posted August 26, 2011 if you have fuel coming out of ur exhaust, you are waaaaaay lean. duh Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted August 31, 2011 Author Report Share Posted August 31, 2011 Gotta love the sarcastic help people give here! Quote Link to comment Share on other sites More sharing options...
camatv Posted September 3, 2011 Report Share Posted September 3, 2011 cause we are the best eva!! Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted September 3, 2011 Report Share Posted September 3, 2011 i have very similar set up,122.5 dumps 52 pilots eej needle 4th clip,short distance the bike likes 3turns out on the pj,in the 1/4 it like 6 turns Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted September 4, 2011 Report Share Posted September 4, 2011 To answer your question, yes you will have to have it under a load and wide open throttle to get any burn on your plugs. The good thing is that that burn on a plug stays on there so you can ride back to the truck or whatever and look at em. Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted September 8, 2011 Author Report Share Posted September 8, 2011 Okay thank you very much! I got it dialed in pretty good. Runs like a beast now. Thanks guys! Quote Link to comment Share on other sites More sharing options...
shanYE west Posted September 8, 2011 Report Share Posted September 8, 2011 so where did your jetting end up? what squish you running? Quote Link to comment Share on other sites More sharing options...
