TheDevil11 Posted August 24, 2011 Report Share Posted August 24, 2011 So -- I was riding at the Silver lake Sand Dunes -- Banshee was running like a top .... after about 2 hours then it bogged to a stall. Couldn't get it to start -- and after about 25 kicks ... it started. I decided to leave for the day since I had trouble restarting it - rode it about 2 minutes towards the exit & couldn't even ride it out of the dunes. It bogged out again and had to be towed to the parking lot. I got it home & took the carbs off and cleaned them throughly -- because I thought maybe sand got in them. Nope -- wouldn't start. Tested spark to the plugs & NOTHING! No spark -- put new plugs in & still nothing. I started moving the front wiring around to make sure everything was connected properly & felt a small spark. So I think it's something electrical. I changed the CDI, voltage regulator, coil, etc... and still no spark. I still have the "Key" --- and thought maybe i should bypass it & hot wire it? Any ideas on where to look next? Thanks! Quote Link to comment Share on other sites More sharing options...
vifferman Posted August 24, 2011 Report Share Posted August 24, 2011 So -- I was riding at the Silver lake Sand Dunes -- Banshee was running like a top .... after about 2 hours then it bogged to a stall. Couldn't get it to start -- and after about 25 kicks ... it started. I decided to leave for the day since I had trouble restarting it - rode it about 2 minutes towards the exit & couldn't even ride it out of the dunes. It bogged out again and had to be towed to the parking lot. I got it home & took the carbs off and cleaned them throughly -- because I thought maybe sand got in them. Nope -- wouldn't start. Tested spark to the plugs & NOTHING! No spark -- put new plugs in & still nothing. I started moving the front wiring around to make sure everything was connected properly & felt a small spark. So I think it's something electrical. I changed the CDI, voltage regulator, coil, etc... and still no spark. I still have the "Key" --- and thought maybe i should bypass it & hot wire it? Any ideas on where to look next? Thanks! Might be the key switch, most guys remove it. Might also be a bad ground. Quote Link to comment Share on other sites More sharing options...
Dicklez Posted August 24, 2011 Report Share Posted August 24, 2011 Check for wires that could have melted from the exhaust. check all connectors make sure nothing is pinched. Best bet is to pull everything off so you can see and inspect the whole harness. Quote Link to comment Share on other sites More sharing options...
DuneBooZeR Posted August 24, 2011 Report Share Posted August 24, 2011 Do you still have TORS connected? A ground may have wiggled loose? If you have swapped all electrical parts, it would be a good idea to checkout the connections on the harness it self. just my 2 cents Quote Link to comment Share on other sites More sharing options...
jjn56 Posted August 24, 2011 Report Share Posted August 24, 2011 could be your stator Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted August 24, 2011 Report Share Posted August 24, 2011 I had the same thing happen to me & is was my stator went bad. Test the stator to see what you have. Also check out the pick up coil & gap. Quote Link to comment Share on other sites More sharing options...
TheDevil11 Posted August 25, 2011 Author Report Share Posted August 25, 2011 Cool ~ I was thinking along those lines --- I will start with a possible bad ground. If anyone else has any ideas -- send them my way!! Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted August 25, 2011 Report Share Posted August 25, 2011 wait......you were moving wires around trying to get it to start? as in the stator was not spinning so your chanrging system was not running so your bike shouldn't have been producing electricity? did you actually see the spark....or did you actually just FEEL the spark. could it have been an old plastic tie on a wire loom or could it have been the old tape that crunched cause its all dry rotted now and that's what you though you felt through a wire? Quote Link to comment Share on other sites More sharing options...
TheDevil11 Posted August 25, 2011 Author Report Share Posted August 25, 2011 wait......you were moving wires around trying to get it to start? as in the stator was not spinning so your chanrging system was not running so your bike shouldn't have been producing electricity? did you actually see the spark....or did you actually just FEEL the spark. could it have been an old plastic tie on a wire loom or could it have been the old tape that crunched cause its all dry rotted now and that's what you though you felt through a wire? Hmmmm - great point! I could feel a spark --- I didn't actually see one. I will check it out today. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted August 26, 2011 Report Share Posted August 26, 2011 my first suggestion is to keep shit simple.....id start with a simple compression test and see what you get. if one cylinder is way lower than the other.....or if both cylinders are below 90 psi you found your culprit. do that test first and then let us know what your test shows. remember.....screw in tester, hold throttle wide open.....kick til guage stops going up (may even take 20 kicks) Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 27, 2011 Report Share Posted August 27, 2011 2 most common in this case- the wires melted on the exhaust, usually at the side of the airbox, or where it would be, and te 2nd- the kieyswitch wire connection. i had this last year myself, and have seen allot with it- the wires, which move allot with steering, can start to break off the keyswitch solder joints. pull the keyswitch off and see how well it is connected to the wires. i just re-solderd mine back on. if you want to bypass, it's the red/black to ground(black) in the harness, or the 2 smaller gauge wires on the keyswitch side of the plug. also, sounds like possibly a bad stator. ohm it out on the red & green and red/white& green/white wires. last, check your coil ohms, and caps Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted August 27, 2011 Report Share Posted August 27, 2011 Get an ohm meter & check your wiring harness & key switch for continuity first. Then check stator & of course compression. Quote Link to comment Share on other sites More sharing options...
TheDevil11 Posted August 27, 2011 Author Report Share Posted August 27, 2011 I have been messing with this for days now --- and i do see spark. I took everything apart again -- carbs, reeds, etc ---- put it back together & nothing. I left the filter off and sprayed gas right into the carb intakes & it friggin fired up first kick!!! What the hell?? I emptied my gas tank thinking maybe I have old gas in it or something. Will try to start it again today. More to come...... Quote Link to comment Share on other sites More sharing options...
camatv Posted August 27, 2011 Report Share Posted August 27, 2011 as stated actually TEST the electrical if yolur not sure how either buy a manual OR find some old guy that bitches about how the things are these days and ask him.. OR find a shop that actually works on banshee's adn see if anyone in there is wirth a shit.. 2nd if you spray gas in i t and it starts you have NO fuel. either turn the gas on OR check the fuel lines for fuel FLOW. if they have flow remove the carbs and take OUT the floats and the needle and seats adn BLOW compressed air through them.. if NO flow remove the petcock and clean it out.. clean off the fuel filters in the tank. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted August 27, 2011 Report Share Posted August 27, 2011 Just to add to what Cam said. Is your gas tank vent working properly? IE, is your steering stem full of water, and the vent hose isn't getting air, or is the vent in the cap all plugged up? Quote Link to comment Share on other sites More sharing options...
