E 85
A couple of my friends are running E 85 in their turbo raptors. I am running full race gas. E85 is waaay cheaper. Can banshee's run on it? I was told that you have to jet 30% higher for E 85, i just dont know if it works with 2 strokes. Also and disadvantages or advantages would be great to know. Thanks ahead of time. I tried searching before I started this thread so im sorry if i am "beating a dead horse".
The same is true for methanol but I don't see guys switching back to race gas. You make up for the " less energy density" by running more.
You will probably have to have your cards setup as alcohol carbs. You will also need to run a premix oil that blends with alcohol. Like klotz supertechniplate, original techniplate, benol, or maxima castor 927.
I was wondering because e85 is waaaay cheaper than race gas. If its hard on the motor and parts, then I will stay away from it for now. Just trying to save some money.
race gas where im at is 6.50 a gallon and methanol is 2.45 a gallon so if you gonna spend money to set ur carbs for e85 you should prolly just run meth instead
biggest problem is mileage... you'll burn up A LOT more alky.. if I had to guess.. you'd burn through a full tank in about 10-20 min depending on the motor.
well if i go through a gallon of race gas in 20mins and 3 gallons of alky in 20 mins i think id pick the alky i get more horse power for the same price
