dannie Posted August 18, 2011 Report Share Posted August 18, 2011 4mil cub vs a 10mil cub Quote Link to comment Share on other sites More sharing options...
SandmanPNW Posted August 18, 2011 Report Share Posted August 18, 2011 Who won? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 18, 2011 Report Share Posted August 18, 2011 difference.. about 6mm worth of stroke.. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted August 18, 2011 Report Share Posted August 18, 2011 And 500 to 1000 dollars. Quote Link to comment Share on other sites More sharing options...
dannie Posted August 18, 2011 Author Report Share Posted August 18, 2011 Witch cub motor would b worth building Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 18, 2011 Report Share Posted August 18, 2011 10mm and be done with it. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 18, 2011 Report Share Posted August 18, 2011 And 500 to 1000 dollars. 10mil cubs are only about 300 over a 4mil.. depending on what the builder charges for trenching. Quote Link to comment Share on other sites More sharing options...
dannie Posted August 18, 2011 Author Report Share Posted August 18, 2011 Would a 4mil out run a 10 mil cub Quote Link to comment Share on other sites More sharing options...
PassionRE Posted August 18, 2011 Report Share Posted August 18, 2011 Would a 4mil out run a 10 mil cub usually...but not always biggest potential=10mill biggest bang for the buck=4mill Quote Link to comment Share on other sites More sharing options...
camatv Posted August 18, 2011 Report Share Posted August 18, 2011 yes Quote Link to comment Share on other sites More sharing options...
gangstahic Posted August 18, 2011 Report Share Posted August 18, 2011 im debating on the same thing but a serval instead of a cub....seems like itd b worth the 300 bucks most builders r saying difference in price to do a 10 mill Quote Link to comment Share on other sites More sharing options...
camatv Posted August 18, 2011 Report Share Posted August 18, 2011 then wys nt talk to da beelder you's plan on ussin hve them answerzzz alll da 1 line queesstenzz youz be asssin Quote Link to comment Share on other sites More sharing options...
PassionRE Posted August 18, 2011 Report Share Posted August 18, 2011 then wys nt talk to da beelder you's plan on ussin hve them answerzzz alll da 1 line queesstenzz youz be asssin By the time you get a decent crank(10mill) its more than $300.00 difference. I wouldnt even consider using these un-named cranks that are floating around currently...not to mention the TDR or Vito's junk. A Twister crank with TZ drive side bearing would be the minimum in quality that should used on a build thats going to exceed 100HP. Your asking for a disaster on a 10 mill build otherwise. The 4 mill builds are way more forgiving than 10 mills when it comes to crank life..Jim Quote Link to comment Share on other sites More sharing options...
camatv Posted August 19, 2011 Report Share Posted August 19, 2011 if i could build a reliable 10 mill for 300 bucks differnce i'd have more than one. the clutch setup in my 535 i ended up using that lasted more than one trip, was 600 bones alone.. i havent tried a matton basket on something with that kinda low end capacity but i think they would hold up ok Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 19, 2011 Report Share Posted August 19, 2011 if i could build a reliable 10 mill for 300 bucks differnce i'd have more than one. the clutch setup in my 535 i ended up using that lasted more than one trip, was 600 bones alone.. i havent tried a matton basket on something with that kinda low end capacity but i think they would hold up ok isn't the forged crankworks cranks 600? thats about 200 more then a 4mil hotrods and case work runs around 100. i dont see a 1000 crank needed on a 10mil cub. Quote Link to comment Share on other sites More sharing options...
