03banshee20 Posted August 15, 2011 Report Share Posted August 15, 2011 03 shee Ssts vf3 +4 timing cool head 20cc domes stock carbs 300 main 30 pilot middle clip stock needle 500 ft elevation. Notice alot of black oil coming out end of silencers and an the front and I know my seals are all good it bogs alot before powerband like I no power I have to slip clutch alot what's goin on??? Helpp has alot of top end Quote Link to comment Share on other sites More sharing options...
volcrano Posted August 16, 2011 Report Share Posted August 16, 2011 what do ur plugs look like????if u ride and pull the choke out in the mid is it better or worse.if better its too lean if worse its too rich.are u running airbox lid or no???? Quote Link to comment Share on other sites More sharing options...
03banshee20 Posted August 17, 2011 Author Report Share Posted August 17, 2011 what do ur plugs look like????if u ride and pull the choke out in the mid is it better or worse.if better its too lean if worse its too rich.are u running airbox lid or no???? yes plugs are black but not bad ive tried airbox on and off makes no diff Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 17, 2011 Report Share Posted August 17, 2011 if the bike has ran like this b4 maybe its your plug caps,but i have allways liked a 280 main 27.5 pilot needles 4th clip with ssts Quote Link to comment Share on other sites More sharing options...
BansheeBoy96 Posted August 17, 2011 Report Share Posted August 17, 2011 Mine was just doin the same thing check ur needle position...... Quote Link to comment Share on other sites More sharing options...
06specialedition Posted August 17, 2011 Report Share Posted August 17, 2011 Move your needle second notch from the top (blunt end). I bet that helps alot. Quote Link to comment Share on other sites More sharing options...
