bigborebanshee Posted August 24, 2011 Report Posted August 24, 2011 front motor mounts.!! used the stock mounts but changed them up a tad.. I did the same on my YFZ,but Im putting a yz465 into it.Just had to cut the original angled mounting tubes off the frame and mount them flat on the bottom.Looks Great! Quote
camatv Posted August 24, 2011 Author Report Posted August 24, 2011 i'd seen one a while back with a YZ 250 motor in it that looked really cool!! if i was more $$$$ in my pocket i'd probably do one. Quote
bigborebanshee Posted August 24, 2011 Report Posted August 24, 2011 A 250 was my original plan,but i had a 81' 465 that was just sitting in the shed.Considering the weight savings in that air cooled engine,it won't have to make big hp to be fast. The 465 was by far the best of the air cooled Yami's. Its amazing how well the older yamaha engines fit into these newer chassis with some minor modifications. Quote
camatv Posted August 28, 2011 Author Report Posted August 28, 2011 did they fix the crappy shifting issues with that motor?? Quote
bigborebanshee Posted August 28, 2011 Report Posted August 28, 2011 did they fix the crappy shifting issues with that motor?? Believe it or not it has the same shift star as the banshee,like shark teeth.I modded it like the one on a banshee,it should shift like butter now. Quote
Coupelx Posted August 29, 2011 Report Posted August 29, 2011 did they fix the crappy shifting issues with that motor?? not sure what engine you are referring to but my yz490 shifts pretty decent. Quote
camatv Posted August 29, 2011 Author Report Posted August 29, 2011 might have been the 400. 2 stroke. i had read that they shifted like total dogg do do.. now that i think about it they may have it better to the 4 larger dis ones. Quote
locogato11283 Posted September 6, 2011 Report Posted September 6, 2011 I'm glad you took the time to build this the right way. Hurry up and finish it and bring it to the LS ride. Quote
alongfortheride Posted September 6, 2011 Report Posted September 6, 2011 I'm glad you took the time to build this the right way. Hurry up and finish it and bring it to the LS ride. are you adding a pair of down bars once you fit the pipes to restore the front frame structure Quote
bigborebanshee Posted September 6, 2011 Report Posted September 6, 2011 I did not restore the engine bar mounts on my 465 hybrid.After I cut them out I now have plenty of room for a custom pipe.If you are really concerned with the strength,you could add some small gussets in the corners.The frame i used already had a TPR kit welded on it. Quote
alongfortheride Posted September 6, 2011 Report Posted September 6, 2011 I did not restore the engine bar mounts on my 465 hybrid.After I cut them out I now have plenty of room for a custom pipe.If you are really concerned with the strength,you could add some small gussets in the corners.The frame i used already had a TPR kit welded on it. just curious Quote
camatv Posted September 7, 2011 Author Report Posted September 7, 2011 yes just behind the upper a-arm mounts ther are 1.25 cromoly tubes fitted and welded in. the pipes clear them fine and the frame will fit out frame pipes with no modifications to the pipes. this was one of my goals. as the other frame i will be doing will have out frame pipes. and i absolutely do not want to have to modify them at all. any inframe pipe will need modified but most seem that the existing sections welds will be able to be cut out and repositioned without changing the demisions of the pipes. the stinger tubes of course will be totally custom. the pipes i have for this one are custom LSR spec, lrd pipes that were built for an outlaw they fit like a glove after the modifications to the frame.. there will be no additional cuts or welding or need for re chrome to be done to the head pipes they will also not stick out of the frame really far. as one of my other goals was to be able to ride it like a 450 is ridden up on th e tank with out burning my legs off.. the drag version may have the full down tube still in it as i am thinking of stretching the front out 14 inches. the oil tank mount tubes will of course be gone. i am planing on building an adjustable length jig for that frame.. as money allows.. i am shooting to have the "test" done for sandfest or at least by HQ..!! Quote
camatv Posted September 7, 2011 Author Report Posted September 7, 2011 in case you missed it this a pic of the frame and motor mock WITH the pipes on as you can see they tuck in very tight to the frame.. Quote
camatv Posted September 7, 2011 Author Report Posted September 7, 2011 side view with pipes.. tomorrow or this weekend i hope to be able to work on it some more. i have a bunch of local builds i need to get done for sandfest and thats going to make this project sit on the back burner for a bit. which sucks! Quote
