esterelbanshee Posted October 10, 2011 Report Share Posted October 10, 2011 SOS pad works wonders on chrome and doesnt scratch at all as long as theres a bit of soap left in it. Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted October 12, 2011 Report Share Posted October 12, 2011 DOnt use oven cleaner. Im posting this from my factory room with 3 3000 gallon tanks of that crap and seeing what goes in it i wont even use that crap in the house anywere. If u must do t breathe in the vapors. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted January 2, 2012 Report Share Posted January 2, 2012 If they're a little rusty, aluminum foil and some Coca-Cola will take it right off (keep em wet when your rubbing). If they're oily some engine degreaser and/or Easy-Off oven cleaner with the yellow cap. What do you do with the coke and aluminum foil? Put the coke on the pipes and rub with foil? Quote Link to comment Share on other sites More sharing options...
Shawn R Posted January 2, 2012 Report Share Posted January 2, 2012 I wish I would have read this. I bought a set of FMF pipes and they are not rusted have some black spots on the chrome. It is not rust as I have used polish and a crap ton of elbow grease and it is coming off slowly...going to try the steel wool and sos pad next. thanks. Quote Link to comment Share on other sites More sharing options...
92 TSi AWD Posted January 2, 2012 Report Share Posted January 2, 2012 I usually use the fine steel wool (#0000 I think?) and WD-40. It works good for small amounts of surface rust. Doesn't work too well if the pipes are heavily rusted. Quote Link to comment Share on other sites More sharing options...
troyzstang Posted January 2, 2012 Report Share Posted January 2, 2012 SOS pads / scotchbrite pads and a shitload of elbow grease. Then a little more elbow grease & mothers and there good to go. Works for me everytime. Troy Quote Link to comment Share on other sites More sharing options...
AC-BANSHEE Posted January 5, 2012 Report Share Posted January 5, 2012 navel jelly on hard rust, then 000 or 0000 steel wool, then mothers "billlit" polish did the trick for me Quote Link to comment Share on other sites More sharing options...
XxJIMBOxX Posted February 6, 2012 Report Share Posted February 6, 2012 Im going through the same thing on the banshee i just bout yesterday. i spent 3hrs on JUST 1 of the tommy 5's. I used WD40 and i real brittle wire brush. it didnt scratch. tomorrow ill start on the other one!!!! the guy i bought it from hadn't cleaned it in 2yrs!!!! its built like 1/4 inch thick hard as rock!!! at one point i took a screw driver and i was tapping it it started to come off in pieces.. not looking forward for tomorrow... lol Quote Link to comment Share on other sites More sharing options...
