Is this Parking Brake Plug?
-Herbie-
Green/yellow is the park brake wire. You want it to be not connected to ground for normal running. Grounding this wire turns on a rev limiter. It does not kill the spark.
So if that is unplugged up front but wires are connected at CDI it shouldn't cause no spark?
Have u ohmed out your spark plug wire/boot lengths for continuity? The harness from cdi to coil? Freshly sanded area at voltage reg ground lug near grab bar??
Yea I am getting a reading of 15,500 on the ohm meter from one spark plug boot to the other. I've tested every wire in the harness and all have continuity from one end to the other. Yea the voltage regulator has a good ground, paint is sanded off frame at mounts.
make sure the black/white wire is not getting ground with the killswitch in run. the black/red wire needs to be grounded (key) and you need to check/ohm your stator and pickup ohms/gap.
Will have to look at the black/white wire, don't recall seeing that one. yea stator checks out in spec with ohm meter and pick-up coil is gapped at .018.
I think i will try swapping out the flywheel from my running banshee next. Not sure what else it could be.
