05bansheeman Posted August 10, 2011 Report Share Posted August 10, 2011 I recently had the head shaved on my shee and i thought i had all th coolant out of my head and when i took it off some whendown on top of piston and i scrambled for a towel but by time i got too it some of it must have seeped down past the rings? what should i do? i dont want to hurt the motor but i really dont wann disassemble it....what should or can i do? what about dumping like a tsp or premiz in there??? any help would bne greatly appreciated thankyou Quote Link to comment Share on other sites More sharing options...
amstall Posted August 10, 2011 Report Share Posted August 10, 2011 it's not that big of a deal. just drain and replace your oil and run with it. if you're real worried about it change your oil run it a bit, change it again then it'll be good for sure. Quote Link to comment Share on other sites More sharing options...
05bansheeman Posted August 10, 2011 Author Report Share Posted August 10, 2011 it's not that big of a deal. just drain and replace your oil and run with it. if you're real worried about it change your oil run it a bit, change it again then it'll be good for sure. its not the oil i worried about, there isnt any amount of oil inder the piston i worried about the coolant eating away at the crank bearings but i not sure if it will or not...or hurt the cylinder wall under the piston Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 10, 2011 Report Share Posted August 10, 2011 Easy fix. Take your carbs and reeds off so you can see your piston. Flip the quad over on its back and move the kicker. After it all comes out put some gas in there and repeat till you feel its all out. Quote Link to comment Share on other sites More sharing options...
05bansheeman Posted August 10, 2011 Author Report Share Posted August 10, 2011 Easy fix. Take your carbs and reeds off so you can see your piston. Flip the quad over on its back and move the kicker. After it all comes out put some gas in there and repeat till you feel its all out. there was prob only a teaspoon that got in there and half of it went down is that even aenought to worry about?? Quote Link to comment Share on other sites More sharing options...
Dicklez Posted August 10, 2011 Report Share Posted August 10, 2011 I wouldn't. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted August 10, 2011 Report Share Posted August 10, 2011 It's not going to hurt anything. Wipe a little oil on the cylinder walls just for cheap insurance, put it back together and fire it up. I personally would do it right away so there's no chance of it rusting the cylinders or bearings. Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted August 10, 2011 Report Share Posted August 10, 2011 it's not that big of a deal. just drain and replace your oil and run with it. if you're real worried about it change your oil run it a bit, change it again then it'll be good for sure. its a 2-stroke not 4, there is no oil under the piston just pre-mix which has oil in it. so draining the oil will do nothing at all for him. Quote Link to comment Share on other sites More sharing options...
05bansheeman Posted August 10, 2011 Author Report Share Posted August 10, 2011 It's not going to hurt anything. Wipe a little oil on the cylinder walls just for cheap insurance, put it back together and fire it up. I personally would do it right away so there's no chance of it rusting the cylinders or bearings. thanx thats wat i did i put about a teaspoon or so of premix there Quote Link to comment Share on other sites More sharing options...
camatv Posted August 11, 2011 Report Share Posted August 11, 2011 it's not that big of a deal. just drain and replace your oil and run with it. if you're real worried about it change your oil run it a bit, change it again then it'll be good for sure. didnt you know everythign you read on the net is absolute truth? Quote Link to comment Share on other sites More sharing options...
05bansheeman Posted August 11, 2011 Author Report Share Posted August 11, 2011 didnt you know everythign you read on the net is absolute truth? absolutely how you think i found the read valves for my 400ex??? lol Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted August 11, 2011 Report Share Posted August 11, 2011 and dual over head cams for my shee. Quote Link to comment Share on other sites More sharing options...
