421 serval?
gotcha how much did that setup cost you? and how long have u been running it?
through m&m the 421 kit (68mm cub cylinders,4mil crank,head, domes, and pistons) was $1700 then with small stuff like billet basket new clutches lock out lockout cover and dunable override i have $2500 into it
Ok so I have decided for sure now I am doing a 421 serval. Now my problem is with who to go with..I see m&m have the complete kit on sale right now for 1400..fast is a little more expensive but I want them doing all the work on it..anyone have any cons on m&m stuff and jeff can u please pm me a price or call me on a complete kit comparable with there's. Thanks guys
i'd recomend a top case fill and match and a billet basket and a stock cut transmission and your gonna need a good clutch also. ( these are for some reason are left out of the recomended builds?)
What is a top case fill? Is that something like case porting to match the cylinders?
Since your basically starting from scratch, You'll need:
cylinders
pistons
4mil crank, welded as well as new bearings
Port match the cases
35 pwks
filters
billet basket
fast clutch
pipes
billet water impeller
Cool head with domes cut for the 4mil and your setup. ie race, pump or alky
I'd recomend a lockout and if your going to run a lockout, you'll need a cover unless your run a gigot.
Pancake bearing
Gaskets and an oring kit
We just got done putting together a fast 4mil with all the above mentioned, was well as a duneable 1-5 and it freakin rips. The power curve on this thing is insane. We run the original set of Rockets on it as well. One thing I've learned over the years of fuckin around with these banshees is that you cant short cut anything. If your going to do it, don't half ass it. You'll save money in the long run. Any of the older guys will tell you the same.
  • Like 1
Yea its definitely getting done right..so hopefully I have a nice 4 mil serval when its done..jeff suggested 35 carbs..so that's what im going with unless anyone gas any opinions. Oh and u will be running in frame shearer pipes..
  • 2 weeks later...
The Serval is going to test your entire clutch and shifting mechanisms.
Now is a good time to do maintenance on the entire clutch system.
All the way from the clutch lever to the pancake bearing.
I would get the following from FAST:
Modded Shift Shaft / Spring and Oil Seal
New Eccentric Screw
New Locking Tab
Billet Basket and New Locking Tab
FAST Clutch and Springs
Pancake Bearing
?Clutch Push Rod and Ball?
?Clutch Actuator and Seal?
?New Clutch Inner Hub?
?New Clutch Pressure Plate?
?Clutch Cable?
Find an Ez Pull Clutch Lever http://bansheehq.com/forums/index.php?showtopic=146323&st=0&p=1261960&hl="ez%20pull"&fromsearch=1entry1261960
They say a lock-up recommended, but people say their FAST Clutch Kit has worked just fine.
Edited by Strm Trpr
Yea I heard about the lock up clutch. So what's the difference in the 2
This link will educate you, it helped me out.
http://www.directdrivecnc.net/banlockout.html
You can also do a search by selecting the little snowflake looking icon in the upper right hand corner of the page.
Type "lock-out" or "lock-up".
Include the quotes and select "search titles only".
