makemefaster Posted August 7, 2011 Report Share Posted August 7, 2011 Banshee FTZ MSD complete ignition assy w/ battery & box. the ignition system is NEW never ran just mounted. the battery and box are used. This is the best top of the line ignition system you can get for a banshee. It has a built in studder box and nitrous trigger switch and a tack output plus comes with two super high out put coils. This system sales for over $800 with out the battery or the custom aluminum box that hides it nicely under the seat. This repaces your intire ignition system ( wire harness , coil, flywheel, stator, and factory switches). The flywheel is only ounces not pounds and allows the motor to rev extremely fast. comes with complete installation and tuning instructions. Asking $375 plus the ride.">">">">"> Quote Link to comment Share on other sites More sharing options...
Trueblown Posted August 7, 2011 Report Share Posted August 7, 2011 Can you run headlights still? Quote Link to comment Share on other sites More sharing options...
makemefaster Posted August 8, 2011 Author Report Share Posted August 8, 2011 I suppose you could it operates on a standard 12 volt battery Quote Link to comment Share on other sites More sharing options...
brownie731 Posted August 12, 2014 Report Share Posted August 12, 2014 already sold i bet huh? Quote Link to comment Share on other sites More sharing options...
brownie731 Posted August 12, 2014 Report Share Posted August 12, 2014 alright well then that is that lol Quote Link to comment Share on other sites More sharing options...
El Bori Posted November 13, 2020 Report Share Posted November 13, 2020 Hi I know is been a while that you sold this set up. But you happen to remember how to install the trigger wheel in the crankshaft. I have one with this set up but have no instructions and this set works with no woodruff key so trying to figure out how to install the in the crankshaft and set the timing correct. I already try to call FTZ but they say is to old set up and they were no help. Thanks Quote Link to comment Share on other sites More sharing options...
SKEETER Posted November 13, 2020 Report Share Posted November 13, 2020 The seller was smart, for getting rid of that junk Quote Link to comment Share on other sites More sharing options...
