shanYE west Posted August 12, 2011 Report Share Posted August 12, 2011 Dgk needle is richer than Cel needle. not entirely true.. the DGK is richer on the Taper and diameter.. teh CEL is richer on the length. Quote Link to comment Share on other sites More sharing options...
beebs Posted August 12, 2011 Report Share Posted August 12, 2011 not entirely true.. the DGK is richer on the Taper and diameter.. teh CEL is richer on the length. You are right now that I look at it closer. C=1.34 and D=1.45 how is that read for taper, does it mean thickness? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 12, 2011 Report Share Posted August 12, 2011 Its the angle. The CEL is richer on the needle length.. not the taper. 38.15 vs 39.95 of the D(G)K First letter is Taper Second is Length Third is diameter CEL Tapper = 1*34' length = 38.15mm and diameter is 2.705mm Quote Link to comment Share on other sites More sharing options...
beebs Posted August 12, 2011 Report Share Posted August 12, 2011 Kadillacman was thinking of switching out to Cel. What do you guys think is that one the best needle to tune the cub with? Quote Link to comment Share on other sites More sharing options...
SpeedRacer88 Posted August 12, 2011 Author Report Share Posted August 12, 2011 Kadillacman was thinking of switching out to Cel. What do you guys think is that one the best needle to tune the cub with? I wanna no the same ... Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted December 7, 2011 Report Share Posted December 7, 2011 Im building the same exact set-up with same bolt-ons. Did you you ever figure out what the issue was with why your motor blew? If so, what jetting did you dail it in with? Quote Link to comment Share on other sites More sharing options...
SLOPOKE21 Posted December 7, 2011 Report Share Posted December 7, 2011 I used to run 15/43 on my 4 mil cub with 12 paddle staggered extremes and im 250 lbs. Quote Link to comment Share on other sites More sharing options...
SLOPOKE21 Posted December 8, 2011 Report Share Posted December 8, 2011 You know I was thinking and when I first got my cub I bought pretty much the same setup as you except I had 39's. I ran a stock swinger with sand stars for a while, but still there wasn't to many times I got beat. Even dirtbikes I would beat. Get some bowls and run the jetting stated then you will have no problems with those guys. Quote Link to comment Share on other sites More sharing options...
