03banshee20 Posted August 4, 2011 Report Share Posted August 4, 2011 what jets should i be running? i have fmf ssts v force reeds cool head 20 cc domes 150 psi comp 400 elevation +4 timing. running 290 mains and 30 pilots seems rich but when i go down to a 280 it is lean. spark plug is black. And it spits oil out the silencers and where the pipe meets the cylinder. dont tell me its my exhaust seals there brand new so are the silencers. and when i get on it and go through the gears it looses fuel and cuts out. idk what to do. Quote Link to comment Share on other sites More sharing options...
shakar Posted August 4, 2011 Report Share Posted August 4, 2011 id go 320 main may be a bit fat and 27 1/2 slow ......what r u runnin for gas ,r u runnin 32 to 1?? goodluck Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 4, 2011 Report Share Posted August 4, 2011 i have ssts, vf3s, ported 350 with 21ccs running 140psi. i do have my lid modded with a big hole and outer ware but im running 27.5 and 310. i live in harrisburg pa i think thats like 800' or so Quote Link to comment Share on other sites More sharing options...
camatv Posted August 6, 2011 Report Share Posted August 6, 2011 put in 300's and then try 310's check your gap, check your ignition try NEW plugs. not the same old ones your bike fouled out 15 mins ago.. if it has an outerware TAKE it off and see if it improves.. Quote Link to comment Share on other sites More sharing options...
Boone Posted September 22, 2011 Report Share Posted September 22, 2011 (edited) Pretty much the same motor as me (minus porting).... I run 290's (perfect) and 30's (perfect) at 300'-800'... You have to be close. Mine blows oil too at the head pipe too... It happens... It's just the nature of the beast (2 strokes) Edited September 22, 2011 by Boone Quote Link to comment Share on other sites More sharing options...
