blue-banshee Posted August 3, 2011 Author Report Share Posted August 3, 2011 Crank seal... not good. right plug is dark black, like that side if fooling up with back ozze. right side it like a white how do i check the pick up gap? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 4, 2011 Report Share Posted August 4, 2011 Crank seal... not good. right plug is dark black, like that side if fooling up with back ozze. right side it like a white how do i check the pick up gap? You also need a carb sync to set the pj's idle speed knobs. That way both carbs are pulling the same amount of air. Quote Link to comment Share on other sites More sharing options...
