sandshred25 Posted July 31, 2011 Report Share Posted July 31, 2011 is there an easy way or trick to getting the wrist pin clip on??? a tool maybe?? a local buddist?? drivin me crazy Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted July 31, 2011 Report Share Posted July 31, 2011 just pinch the clip with the gap infront, make sure the clip gap is away from the recess on the piston (where you get it out from) push the clip in on and angle in the hole, and push it in then push the bottom of the clip into the groove. Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted July 31, 2011 Report Share Posted July 31, 2011 I got a trick to getting them in with only a small flat head,but i cant really describe it,i would have to do a video Quote Link to comment Share on other sites More sharing options...
sandshred25 Posted July 31, 2011 Author Report Share Posted July 31, 2011 I got a trick to getting them in with only a small flat head,but i cant really describe it,i would have to do a video a vid would be cool,, theses things are giving me grey hairs,,,, thats my daughters job Quote Link to comment Share on other sites More sharing options...
sandshred25 Posted July 31, 2011 Author Report Share Posted July 31, 2011 just pinch the clip with the gap infront, make sure the clip gap is away from the recess on the piston (where you get it out from) push the clip in on and angle in the hole, and push it in then push the bottom of the clip into the groove. pinch with fingers? or needle nose?? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted July 31, 2011 Report Share Posted July 31, 2011 fingers. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 31, 2011 Report Share Posted July 31, 2011 It's very easy to do with some needle nose pliers. Make sure you cover the crank case just in case you drop the clip. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 1, 2011 Report Share Posted August 1, 2011 A pick set really helps out. Just start the one end and lip it around. Quote Link to comment Share on other sites More sharing options...
sandshred25 Posted August 1, 2011 Author Report Share Posted August 1, 2011 once again thanks for all the help,, this site rocks Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 1, 2011 Report Share Posted August 1, 2011 6 bucks at lowes http://www.lowes.com/pd_239658-930-324621N_0__?zipCode=68358&firstReferURL=http%3A%2F%2Fwww.lowes.com%2Fpd_239658-930-324621N_0__%3FproductId%3D1207839%26Ntt%3Dpick%2Bset%26pl%3D1%26currentURL%3D%252Fpl__0__s%253FNtt%253Dpick%252Bset%26facetInfo%3D&catalogId=10051&productId=1207839&pl=1&findStoreErrorURL=StoreLocatorDisplayView&selectedLocalStoreBeanArray=%5Bcom.lowes.commerce.storelocator.beans.LocatorStoreBean%4058f6df2c%2C+com.lowes.commerce.storelocator.beans.LocatorStoreBean%405816df2c%2C+com.lowes.commerce.storelocator.beans.LocatorStoreBean%405836df2c%2C+com.lowes.commerce.storelocator.beans.LocatorStoreBean%405856df2c%2C+com.lowes.commerce.storelocator.beans.LocatorStoreBean%405876df2c%5D¤tURL=%2Fpl__0__s%3FNtt%3Dpick%2Bset&Ntt=pick+set&URL=TopCategoriesDisplayView&langId=-1&storeId=10151 Quote Link to comment Share on other sites More sharing options...
sandshred25 Posted August 1, 2011 Author Report Share Posted August 1, 2011 6 bucks at lowes http://www.lowes.com/pd_239658-930-324621N_0__?zipCode=68358&firstReferURL=http%3A%2F%2Fwww.lowes.com%2Fpd_239658-930-324621N_0__%3FproductId%3D1207839%26Ntt%3Dpick%2Bset%26pl%3D1%26currentURL%3D%252Fpl__0__s%253FNtt%253Dpick%252Bset%26facetInfo%3D&catalogId=10051&productId=1207839&pl=1&findStoreErrorURL=StoreLocatorDisplayView&selectedLocalStoreBeanArray=%5Bcom.lowes.commerce.storelocator.beans.LocatorStoreBean%4058f6df2c%2C+com.lowes.commerce.storelocator.beans.LocatorStoreBean%405816df2c%2C+com.lowes.commerce.storelocator.beans.LocatorStoreBean%405836df2c%2C+com.lowes.commerce.storelocator.beans.LocatorStoreBean%405856df2c%2C+com.lowes.commerce.storelocator.beans.LocatorStoreBean%405876df2c%5D¤tURL=%2Fpl__0__s%3FNtt%3Dpick%2Bset&Ntt=pick+set&URL=TopCategoriesDisplayView&langId=-1&storeId=10151 nice man,, i could find a million uses for those Quote Link to comment Share on other sites More sharing options...
vifferman Posted August 1, 2011 Report Share Posted August 1, 2011 I got these for 1$ at .... The Dollar Store. Yeah, they aren't Kobalt but they work just fine. Quote Link to comment Share on other sites More sharing options...
Koolguyson Posted August 1, 2011 Report Share Posted August 1, 2011 nice man,, i could find a million uses for those I want a list of at least 100 things right now. Ready? Go! On a cereal note, they are simple to install. Wedge the center of the clip into the piston groove. Squeeze the gap end with your fingers. Press the clip "ends" in as far as you can. Then with a small pocket flat blade, just finish installing the clip. Make sure you hear it SNAP. An improperly seated clip will absolutely destroy your motor. And always cover the crankcase with a rag so you don't drop the clip inside the motor. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 1, 2011 Report Share Posted August 1, 2011 I will start tooth pick finger nail cleaner awl scribe corn on the cob holders Hold a 3 layered club sandwitch together Deflate the tires on your ex girl friend's car Quote Link to comment Share on other sites More sharing options...
sandshred25 Posted August 1, 2011 Author Report Share Posted August 1, 2011 I will start tooth pick finger nail cleaner awl scribe corn on the cob holders Hold a 3 layered club sandwitch together Deflate the tires on your ex girl friend's car LMFAO Quote Link to comment Share on other sites More sharing options...
