Kx125 into blaster ( i know this has nothing to do with a Banshee)
Thanks for all the smart ass comments.. Meant to say gfs brother. Was in a hurry when i typed this. Just wanted to see if anyone has done this or anything close to it and how it worked
no, never done the girfriends brother before, but i can tell you not to focus too much on grunt/torque on the blaster. they like to pop up pretty good with the stock motor, but really lack in the long
Ok i got the motor out of the bike and the blast today in a couple hours. Now i set the kx into the blaster frame just to see where about the sprockets would be. Turns out they line up perfect when the swing arm bolt mounts the motor in so that took alot of worry out of the built. Now the problem is the kx motor mount for the swing arm is bigger then the space in the swing arm for it. Im supposed to chop out part of the swing arm by the bushing/bearing right? Just customize it to fit the motor or what do i do? Cant go any farther till i know. Hopefully you guys can help
I cut out what i needed and the motor has the rear motor mount in. Now i have to make the rest of the motor mounts. Ill post pics as soon as i figure out how to. Lol Looks pretty cool so far. Took off that ugle blaster light, put all the kx wiring in, took off the kill/light switch and put the kill button off the bike on the wheeler. Kick starter from the bike wont work though. Maybe a 250 kx will fit or maybe i can get the blaster one on the kx motor. Idk yet. Anybody know which kickstarters from other machines fit on a kx? Or should i just grind away what i need to clear the frame. It isnt very much.
Pretty sure i got the kickstarted problem figured out too. Ill post pics of where im at tomoro. Got pretty far in the little bit of time ive worked on it. Radiators and an airfilter and the machine will be running. Then the rest will be jetting, gearing, and making a beafy grab bar
