guns4children Posted July 25, 2011 Report Share Posted July 25, 2011 Ok guys this is the problem. I was out riding and my quad started bogging down like a foul a plug. I stopped and changed the plugs and it seemed to get a little better than it did it again and we thought I had sucked some dirt into the carbs and clogged them up so we called it a day and went home. Today I cleaned the carbs one at a time so I didn’t mix anything up. Put everything back together and it fired right up and revs like a champ in neutral. I put it up on a tire with the wheels off the ground and shifted into first and it revs like it should, but as soon as I put it on the ground it just bogs and wont rev. it’ll tractor around the yard at like 2 miles an hour with the throttle held wide open but that’s all it does. Does anyone know what it could be? oh yeah and i have no tors and no parking brake they have been gone for a wile now. Quote Link to comment Share on other sites More sharing options...
ECshee Posted July 25, 2011 Report Share Posted July 25, 2011 did it get wet? Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 did it get wet? nope it was like 103 out and no water around Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 TTT Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted July 25, 2011 Report Share Posted July 25, 2011 Id start with the typical stuff. New plugs, check gap, check compression, reclean carbs, clean air filter, check wiring, fresh fuel..... Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 iv had the tors and parking brake off for a wile but is there anyway for that to come back into play? Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 yeah man its nuts. it was jetted just fine till this all started. we put another set of carbs on it and it does the same thing. i was hoping someone had this same prob and it was an easy fix. Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 ill go look. never thought the chain being to tight would do that. Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 chain is fine and it kinda makes me sad cause i changed the sprockets and i thought maybe i had it to tight but its just fine even with my fat ass sitting on it. it sounds good up untill i put it in gear and it just putts out and wont rev. but it does move at like 2mph. makes me sick to think about. Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 maybe too much oil in the tranny? i remember i filled my tranny up way to much in my zilla and it didn't want to rev or take off. once i drained some it rans way better. just a thought i dont think its that cause i didnt add or take any out but im going to look at it cause i dont know the last time i even looked at it Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted July 25, 2011 Report Share Posted July 25, 2011 have you checked your air filter.....is it plugged full of shit that wont let air through enough to run under load? Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 ill try taking the pods off and seeing if it runs like that but right now its raining like a mofo Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 25, 2011 Author Report Share Posted July 25, 2011 ill try taking the pods off and seeing if it runs like that but right now its raining like a mofo took the pods off they were dirty is hell and tryed it with out pods and it runs 100% better! yay! i feel dumb for not trying that in the first place. i also found a big rip in one so im prob going back to the stock box. ill have a better place to test it after i get it to my buddys house. cops dont like loud quads riding the streets of downtown camphill. thanks for all the help guys Quote Link to comment Share on other sites More sharing options...
camatv Posted July 26, 2011 Report Share Posted July 26, 2011 outerwares? if you cannot see through them they wont let any air in although if you cleaned the carbs, you should have done the filters also. ?? compression test. make sure your parking brakes wires are done right. if all the normal stuff checks fine try gap at pickup and CDI Quote Link to comment Share on other sites More sharing options...
snackpac Posted August 8, 2011 Report Share Posted August 8, 2011 outerwares? if you cannot see through them they wont let any air in although if you cleaned the carbs, you should have done the filters also. ?? compression test. make sure your parking brakes wires are done right. if all the normal stuff checks fine try gap at pickup and CDI when you say pods what are you refering too Quote Link to comment Share on other sites More sharing options...
