think i blew my engine today..
  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
So I can definitely see the right piston when I took the exhaust off and piston rings are bent and there were some pieces in the exhaust that I shook out.
did you see the stock stroke cub cyls with pistons that M&M has in the forsale section? You could offset some of the price by selling your old cyls and you would be just a few bucks from a port,bore and pistons on your stock cyls...
Just an idea.
So im trying to get rid off all my stock stuff so I can get this thing fixed. Let me know if anyone is interested. Stock carbs with tors, stock exhaust, stock box with pro flow and k&n filter and outerwear and whatever else is coming off the engine that I don't need..
alright well finally had the time to take my engine apart and its not as bad as i thought. right cylinder definately fried the pistion rings and left a mark on the walls.
heres pics of the domes reeds and pistons. let me know what you guys think.
domes..
are these reeds any good??..
left side..
piston..
Head looks okay, ?might just need a hone on the jugs? time for new pistons, reeds are stock and can't tell their condition by the pictures but an upgrade is fairly cheap and really easy.
Once you take the cylinders off you can check further.
I'm not a engine pro but I did stay at a Holiday Inn Express last night...
Looks just like mine did... Your description was dead on to mine. Glad you got it figueed out now time to blow some cash. Check the forsale section theres a nice dune port set up cheap And the cub. Also split the case to find the peices!
i have a question.. what all is needed for a 421 serval? and what are the advantages and disadvantages of doing this setup.. i also found this ad and was wondering if i should buy this..
http://bansheehq.com/forums/index.php?showtopic=145937
I would be leary of someone with that low of a post count, didn't look at join date :confused::cheers:
just looked, as of now he hasn't been a member for 24 hrs. :jesterlaugh:
Edited by Larry's Shee
