barahonapr Posted July 25, 2011 Author Report Share Posted July 25, 2011 I will do a compression test right after work and take pics of the readings. As for the leakdown test I also have to get the stuff to do that.. Quote Link to comment Share on other sites More sharing options...
volcrano Posted July 25, 2011 Report Share Posted July 25, 2011 make sure the engine is at operating temps when testing compression.so yes,wear gloves.for shits and giggles unplug the tors box on the left side frame upbove pipe. Quote Link to comment Share on other sites More sharing options...
barahonapr Posted July 26, 2011 Author Report Share Posted July 26, 2011 Ok I need to post up pics but don't know how..what's the best way to get good size pics on here Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted July 26, 2011 Report Share Posted July 26, 2011 Photoshop, got an account? Quote Link to comment Share on other sites More sharing options...
barahonapr Posted July 26, 2011 Author Report Share Posted July 26, 2011 (edited) ok so did the compression test and the results were not good.!.. first pic is the left and second the right. Edited July 26, 2011 by barahonapr Quote Link to comment Share on other sites More sharing options...
prssantana Posted July 26, 2011 Report Share Posted July 26, 2011 looks like rebuild time. I would guess either ring hang or a melted piston would be responsible. On the plus side its the perfect time to get it ported Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted July 26, 2011 Report Share Posted July 26, 2011 I just realized I put Photoshop instead of Photobucket lol. Glad you got them posted and yes I agree, may as well take it all out and give it a good going over from top to bottom. Do it right the first time and you won't have to do it again, for a while at least. Quote Link to comment Share on other sites More sharing options...
barahonapr Posted July 26, 2011 Author Report Share Posted July 26, 2011 so just talked to jeff at F.A.S.T.. dam that guy reallly helped me out and gave me advice. heres what to come per the estimate he gave me.. let me know what you guys think. im sure it all sounds good because ive heard nothing but great things coming from this guy. Qty Description Rate Total Aggressive Dune/Play port stock stroke Banshee Case Porting 1 True/Weld Crank 2 Bore/Hone Cylinder 2 Wiseco 513M06425 (.10 Over) just estimate of what he thought..considering its stock and he hasnt looked at it.. 1 F.A.S.T. Head - Silver 1 20cc Domes Prem. Gas 1 Banshee Adjustable Timing Plate 4 Reed Gasket 2 Base Gasket 1 Banshee Clutch Gasket 1 Folding Lock Washer 1 1211 Sealer 1 Crank Seal - Clutch Side 1 Crank Seal - Flywheel Side he also recommended 35mm carbs with some cpi, shear pipes.. Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted July 26, 2011 Report Share Posted July 26, 2011 (edited) So are you sending it to him to let him actually build it or just do the necessary work that you have listed? Personally I'd send my stuff to Herr Jugs. I've seen Kevin's work and it's top notch just as I'm sure Jeff's is except Kevin did my brother-in-law's top end in 10 days from the time he shipped it from his house to the time he got it back. Jeff took almost 3 months just to weld my crank... Just my opinion anyway. Edited July 26, 2011 by bigblockbanshee Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted July 26, 2011 Report Share Posted July 26, 2011 You just having your crank welded or getting new? if your already getting new might as well go 4 mill!! JMO Quote Link to comment Share on other sites More sharing options...
barahonapr Posted July 26, 2011 Author Report Share Posted July 26, 2011 Wow well that's definitely something to look at but yes everything listed he will do and put together.. as for herr is there a site I can check out? They a sponsor? I just want my shit done right ya know. Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted July 26, 2011 Report Share Posted July 26, 2011 http://www.herrjugsracing.com/index.html Where are you located? Quote Link to comment Share on other sites More sharing options...
barahonapr Posted July 26, 2011 Author Report Share Posted July 26, 2011 savannah georgia Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted July 26, 2011 Report Share Posted July 26, 2011 (edited) Ahh nice town, been there and Tybee several times. Anyway, it's kinda a catch-22 here. I'm not sure how Jeff is "normally" on turnaround time but he is closer to you. Kevin (Herr Jugs) is out on the West coast but his specialty is his turnaround time. I've heard several stories of people getting complete engines back in 3 weeks or less, and of course the example I gave above was a top end in 10 days from shipping out to delivery. On the mere quality of work, I can't really say exactly who would be the better outcome but I have seen and experienced Kevin's work and it is amazingly nice, consistent, and clean. I'd shop around a bit though, FAST and Herr Jugs aren't the only ones around. You have Passion, Wildcard, CP Customs, etc... Just go through the site sponsor list and pick your poison. I've heard some sketchy info on CP Customs before but don't know if it's true or not. I've seen some of their work too and rode a 421 with a set of ported jugs from them and it ran really hard. May wanna look into that one a little further before you go that route though. I'd hate to send my stuff to a dishonest builder. I really don't even know if they're still in business or not come to think of it. Edited July 26, 2011 by bigblockbanshee Quote Link to comment Share on other sites More sharing options...
barahonapr Posted July 26, 2011 Author Report Share Posted July 26, 2011 so i found this on juggs to whats comparable to F.A.ST...let me know which one is better and why plz! +4 Mil stock cyl, up to 80HP $1070.00 + $85 option for domes + $169 option Cool Head This comes with a full port job of your choice on your stock cylinders. Drag ports extra. +4 mil crank, bearings, pistons, rings, cir clips, wrist pin and bearings, bore & hone and gaskets for assembly. Send your cylinders in today for the porting and in 2 weeks or less back they come with all the parts for your 4 mil build Quote Link to comment Share on other sites More sharing options...
