they are decent.
i dont know if they are cometic ones, but the reed gaskets ive had from wildcardracing and fast have been the cometic style, afm i think they call them, with the steel insert and rubberised coating.
i prefer the afm whenever possible. they are also easier to case match than paper.. also on the base gasket they are less prone to have a failure. the OEM base gasket is reinforced as is a bunch of aftermarket gaskets. i know, tusk is and athena, the afm also removes much easier and wont stick and rip like the paper gaskets. wonder if cometic would make a clutch cover gasket out of that stuff hmmmm
  • 2 weeks later...
they are cheap paper. id steer clear of them.. even TUSK top end gaskets are a metal based material. and they are like 16 bucks
HA sell them to your friend best thing i can tell you with them is put them on dry dry dry after a lil while the fuel will start to seep through them and they will blow out at least thats what has happend when i tried them a long time ago.
Im not going to sell them to my friend cause then his shee going to have bad quality gaskets on it & plus im the one that works on the shee for him. will sell them to a perfect stranger tho...... :D
We cut our own gaskets with a die cutter and use the best interface solutions material available. We don't sell just gaskets but with our parts you will get a gasket that will likely be reuseable over and over again. Note that they are intake gaskets. Most gaskets you get are out of pf-4n interface soutions and that is because they are made on a leased cutting machine which only provides for that material. Pf-4n is the cheapest material you can get and although it is good material it is the cheapest from interface solutions. What we use is 3 times the cost but well worth it. Not to say that the metal based materials are not great or better but in the material we use holds up and performs properly for many millions of years. Yes, it is proven that this material was around with the dinosaurs and believe it or not was the same material alien aircraft is made of!!!
Jerry
Jerry
How much for two base gaskets
