Aquired New Banshee
I have aquired a Banshee from a friend... It has some pretty serious motor issues so I will be sending it somewhere.. My question is since the bike sat for around 3 years... What else should need replacing? I assume the chain goes bad sitting...
Ps all fluids in the motor will be replaced during the build and the carbs cleaned...
Thanks for any input
Nope.. keihen pwk flat slides... And when he blew the motor it sat 3 yrs I have it now riped it open... Cranks bad .. Needs bored... etc etc... Just don't want to miss something stupid that came up because of it's extensive sitting period
the chain wont go bad.....replace all the fluids....INCLUDING THE FUEL. clean those carbs good. then check the entire bike over......last thing you want to do is fire it up and take a hard run on it and realize your buddy pulled the brake pads off to change em 3 years ago.
Just use common sense about looking at your bike and reassembling your motor.
ALSO make sure you do a leak down test BEFORE you fire the motor up. i usually do them after i finish the assembly while its still out of the frame.
