Jgspahn Posted July 21, 2011 Report Share Posted July 21, 2011 I bought two stock carbs, bored out to 27.5mm, and with the TORS deleted. #1- What is the TORS delete. #2- Does this change how the carbs are installed and/or maintained. Quote Link to comment Share on other sites More sharing options...
Dicklez Posted July 21, 2011 Report Share Posted July 21, 2011 Also if your installing these carbs to replace carbs with tors, You can just remove all the TORS wiring. The E brake wires can also be removed. I just cut all that shit out of my harness. Quote Link to comment Share on other sites More sharing options...
Jgspahn Posted July 21, 2011 Author Report Share Posted July 21, 2011 What are the benefits of having them removed? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted July 21, 2011 Report Share Posted July 21, 2011 What are the benefits of having them removed? Most people remove them because they eventually start to have problems. Whether its the brain or the micro switch in the throttle.....it still does almost the same thing. If yours goes bad you will have symptoms of barley running and wont rev at all....if it runs. you can diagnose it real quick and easy by unplugging the brain box that cuts the spark.....its the little black box that's under your gas tank on the left side of the bike. Another reason people will remove them is to allow quicker access along with easier access to the carbs. If i need to pull my carbs now, i can literally have both of them off in roughly 5 minutes. If you still have the tors on your bike youd be lucky to have the tors units disconnected by the 5 minute mark. Quote Link to comment Share on other sites More sharing options...
camatv Posted July 22, 2011 Report Share Posted July 22, 2011 they are removed becuse torrs sucks nut sweat they get in t he way they are all bulky and stupid looking they make removing the carbs a pain in the butt they make jetting changes harder they they should be already they were stupid to even be put on the atv in the first place. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted October 10, 2011 Report Share Posted October 10, 2011 Does anyone have a post with pictures on how to do the delete? Do I just remove and cut the harness or is there something I need to buy? I want to get rid of the TORS before something does happen. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Dicklez Posted October 10, 2011 Report Share Posted October 10, 2011 Does anyone have a post with pictures on how to do the delete? Do I just remove and cut the harness or is there something I need to buy? I want to get rid of the TORS before something does happen. Thanks in advance. I cut it all out but you dont have to. Just unplug everything and tie it up out of the way. Unplug the little black box under the left side fender. Then you have to buy the tors delete kit which should include the throttle cable with new carb caps and idle screws that you have to install in your carbs. Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted October 10, 2011 Report Share Posted October 10, 2011 Quote Link to comment Share on other sites More sharing options...
