How to remove and replace J arm bushings
salmon_slayer06
the bushings at the frame are replaceable.
the ball joints are not.
replacement of the bushings is pretty straight forward uses same bushings as an a-arm kit. you might want to replace the sleeve's that the busings ride on if they are worn. remove the arm, removethe sleve, tap out the busings with a long punch or long flathead screw driver and then install the new ones if they wont slide right in you can tap them in very lightly with a rubber mallet or use a piece of all thread to pull them in place.
if the bal joints are shot adn it needs bushings just get replacement j-arms then you can get whatever width you might need also
