Chain cutting
first thing i would do is check the swing-arm bearings at the frame. just thrust the rear grab bar side to side and look for play at the frame. then check your sprocket and sprocket hub for play, wear, and count the teeth. should be 14/41 stock.
The swing arm bearings are new as well the sprockets. Im in the process of finishing a rebuild on the bike. I dont have a chain roller I dont think. I have a chain guide on the top of the swingarm and a plastic guide the chain goes through that bolts on the bottome of the arm. Do I need a roller, it never had one with the old chain?
You should have two rollers. Not sure about the top roller but if you don't have the lower roller in place or if the chain is under it, it will seem really loose. Before you take any links out of your chain test fit it with both rollers and both guides in place.
Yes you should have two rollers, swingarm chain guide, and swingarm chain support. The lower roller acts as a tensioner when the swingarm is pointing down. Im at work and don't have a pic right now. Any body have one?
I have the swingarm chain guide and the chain support, do the rollers just bolt on to the frame? The old chain didnt have rollers at all so that is why im confused about it. A picture of it would be awesome if someone has one.
i don't have a pic on hand, but you can get a replacement roller at any power sports shop, just check the bolt size. the hole is located a few inches back from where the swinger bolts. it's on a kind of ear/tab. i wanna say i went with a 1.5" roller on mine
Thanks for all the help guys i figured it out and ordered new rollers, they will be here friday and hopefully this weekend I can get my new serval out on some trails! Thanks.
