Sands Posted July 17, 2011 Report Share Posted July 17, 2011 (edited) I have a Cheetah Cub 421cm3 ( 4mil ), Keihin PKW39 with billet bowls, PowerHead with 22cc dommes, VForce3, 5 degrees timing, Shearer SBIF. Where I live is very close to sea. The elevation is 300feet max. I use 98ron fuel. The temperature is about 25-35 degrees Celsius and atmosphere pressure is 1008mBar. What pilots and mains should I use? May I use 20cc dommes? And 6 degrees timing? Regards. Edited July 17, 2011 by Sands Quote Link to comment Share on other sites More sharing options...
