Big bore questions
ok ive seen a few sets of big bore cylinders for sale. and i am curious how to make stock cylinders into a big bore, being as i believe the stock cylinders are maxed out at 66.5 mm....but ive seel some that are 69mm so how exactly do you make them into big bores? is it using a different sleeve?
  • 2 months later...
"Sleeves are the way to go for anything other then drag racing."
NO, NO THEY ARE NOT! My motor has been one long culmination of issues and after sorting it all out, the motor still gets out ran by standard cylinders with solid port work. And Im not talking about drag bikes either. Old tech, Old theory, old school thought.
However, I ran a set of weld up cylinders that arlen formerly of LRD set up, and they absolutely killed almost anything short of a properly set up cub. but when you factor in the cost of sleeving($4-500) decking($50) tig & rework transfers/Porting ($750-850) A few years ago that would of been the top dog, but now with the availability of aftermarket cylinders you would be a fool to pay some one to build you proper big bore cylinders.
Edited by trickedcarbine
