MacRacer1 Posted July 8, 2011 Report Share Posted July 8, 2011 Well i have a 5 gallon can of race fuel for my banshee, and i dont know if it has two stroke oil mixed in with it are there ways if telling? Quote Link to comment Share on other sites More sharing options...
okbeast Posted July 8, 2011 Report Share Posted July 8, 2011 Pour some out and set it on fire. If it smokes it has oil in it. Best way we've found lol Quote Link to comment Share on other sites More sharing options...
figuare9 Posted July 9, 2011 Report Share Posted July 9, 2011 Grab a clear glass.. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 9, 2011 Report Share Posted July 9, 2011 Pour some out and set it on fire. If it smokes it has oil in it. Best way we've found lol Gasoline genneraly smokes when you set it on fire. Pour a little in to a metal cup and set it on fire. If their is an oil residue left then it is mixed. Quote Link to comment Share on other sites More sharing options...
okbeast Posted July 9, 2011 Report Share Posted July 9, 2011 Gasoline genneraly smokes when you set it on fire. Pour a little in to a metal cup and set it on fire. If their is an oil residue left then it is mixed. I guess I forgot to add that part too. We do it on concrete and it leaves a residue if it has oil in it. Quote Link to comment Share on other sites More sharing options...
vifferman Posted July 9, 2011 Report Share Posted July 9, 2011 Besides tasting it burning seems to work best. I usually just pour some in a cup and if it has oil the oil with remain after the gas evaporates. Some oil has a tint to it so you can see that it has been added. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted July 9, 2011 Report Share Posted July 9, 2011 fill your buddies shee with it........easy way to know if its mixed or if its not mixed. just make sure when he melts down that you go take back your race gas after he has to pull his tank......and mix.... Quote Link to comment Share on other sites More sharing options...
Paulie B Posted July 9, 2011 Report Share Posted July 9, 2011 fill your buddies shee with it........easy way to know if its mixed or if its not mixed. just make sure when he melts down that you go take back your race gas after he has to pull his tank......and mix.... 2 stroke oil is supposed to add color to the gas for that reason. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted July 10, 2011 Report Share Posted July 10, 2011 It should be alot darker if mixed. Once I put Klotz in my gas it turns a darker red color. Quote Link to comment Share on other sites More sharing options...
SheezFast02 Posted July 10, 2011 Report Share Posted July 10, 2011 Run it through your lawnmower. I run all my old bad gas through my lawnmower, mixed or not lol. If it smokes, you've got mixed fuel. If it doesn't, go pick up some Amsoil. Quote Link to comment Share on other sites More sharing options...
Meat Posted July 10, 2011 Report Share Posted July 10, 2011 Step 1. Buy 5 more gallons of gas. Step 2. Remove a few ounces of this new gas and put it in a clear jar. Step 3. Mix oil with new gas, remove a few ounces of this mixed gas and put it in a clear jar. Step 4. Remove a few ounces of the unknown-mixed gas and put it in a clear jar. Step 5. Compare the three gasses. Step 6. Profit Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 10, 2011 Report Share Posted July 10, 2011 2 stroke oil is supposed to add color to the gas for that reason. Yep but if your running colord race fuel then it is hard to tell. VP Red with Klotz oil is hard to tell by color. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 10, 2011 Report Share Posted July 10, 2011 Besides tasting it burning seems to work best. I usually just pour some in a cup and if it has oil the oil with remain after the gas evaporates. Some oil has a tint to it so you can see that it has been added. I just burn mine to speed up the evaporation process, not to see if it smokes. Quote Link to comment Share on other sites More sharing options...
NYUK Posted July 10, 2011 Report Share Posted July 10, 2011 taste it. if it taste like straight gas its not mixed.if it has an oily taste u mixed it. Quote Link to comment Share on other sites More sharing options...
