donkeypuncher Posted July 8, 2011 Report Share Posted July 8, 2011 went riding over 4th of july and after a few rides my clutch started slipping. i could launch hard all day in second but as soon as i would hit around 1/2 to 3/4 throttle (of basically every gear) it would rev hard but wouldnt move all that fast untill i eased up a little. anyways, i have a FAST clutch kit and was wondering if anybody knew how thick the fibers are supposed to be? i need to know if i can continue to run this clutch with a little adjustment (adjustment was off to begin with). Quote Link to comment Share on other sites More sharing options...
Zwiser Posted July 8, 2011 Report Share Posted July 8, 2011 wear limit is 2.7 mm and new should be 3mm Quote Link to comment Share on other sites More sharing options...
shanYE west Posted July 8, 2011 Report Share Posted July 8, 2011 if you ran it with the clutch out of adjustment.. you probably burnt the pack. Maybe Jeff will chime in with the specs of his fibers.. But if it was me.. I'd be buying a new pack.. Quote Link to comment Share on other sites More sharing options...
donkeypuncher Posted July 8, 2011 Author Report Share Posted July 8, 2011 if you ran it with the clutch out of adjustment.. you probably burnt the pack. Maybe Jeff will chime in with the specs of his fibers.. But if it was me.. I'd be buying a new pack.. i hope its not burnt. this was my first trip with it. i measured the fibers and they're all between 2.92-2.95 mm thick. so if zwisers measurements are correct then i would think they would be safe to run. i have a spare clutch kit from HJR that measures between 2.94-2.98 mm thick i guess i could use.....? Quote Link to comment Share on other sites More sharing options...
bike wizard Posted August 21, 2020 Report Share Posted August 21, 2020 Are you running a synthetic oil in your transmission? If you are it will make your clutch slip. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 23, 2020 Report Share Posted August 23, 2020 On 8/21/2020 at 2:14 PM, bike wizard said: Are you running a synthetic oil in your transmission? If you are it will make your clutch slip. That's not necessarily true about synthetic oil. Most is wet clutch compatible. And this post is over 9 years old. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted August 24, 2020 Report Share Posted August 24, 2020 On 8/21/2020 at 12:14 PM, bike wizard said: Are you running a synthetic oil in your transmission? If you are it will make your clutch slip. I've been running synthetic Klotz MTL in mine for over 20 years and the clutch has never slipped at all! Makes it shift better than anything else I have tried- engine oil, Bel Ray Gearsaver, ATF, Honda trans oil and more. Quote Link to comment Share on other sites More sharing options...
bike wizard Posted September 5, 2020 Report Share Posted September 5, 2020 Is that maybe semi synthetic because i have had dozens of bikes and quads that synthetic oil slicked up the plates to the point of slipping . When you take it apart it still looks like brand new but it will not grab in the higher gears under a lot of throttle. Quote Link to comment Share on other sites More sharing options...
bike wizard Posted September 5, 2020 Report Share Posted September 5, 2020 This post might be 9 years old but it might help somebody else out now. And i don't know why some synthetics will and some won't but i know first hand that it can. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted September 5, 2020 Report Share Posted September 5, 2020 I’ve used full synthetic with zero issues. Needs to be for wet clutch. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
