blubyyou Posted July 5, 2011 Report Share Posted July 5, 2011 I am trying to get my pwk 35 a/s carbs dialed in. I have a good plug chop with the mains but its lazy getting into the power band in 4-6 gears. 1-3 it hits hard but I still feel like its a little lazy. I can get it to hit the power band if I clutch it a little in 4-6 gears. My plugs are a dark brown and oily if I ride it for like 30 minutes. I run 927 @ 40:1 on 93 pump gas. My question is do I need to step down on mains again or lean out the needle with the clip? I want it to be crisp and get it to where the plugs aren't oily. I know I'm rich but according to the plug chop the main is good to go...I assume its the needle or could it be a combination of both. I have pics of plugs if u need to see them. Thanks Quote Link to comment Share on other sites More sharing options...
Paulie B Posted July 9, 2011 Report Share Posted July 9, 2011 I am trying to get my pwk 35 a/s carbs dialed in. I have a good plug chop with the mains but its lazy getting into the power band in 4-6 gears. 1-3 it hits hard but I still feel like its a little lazy. I can get it to hit the power band if I clutch it a little in 4-6 gears. My plugs are a dark brown and oily if I ride it for like 30 minutes. I run 927 @ 40:1 on 93 pump gas. My question is do I need to step down on mains again or lean out the needle with the clip? I want it to be crisp and get it to where the plugs aren't oily. I know I'm rich but according to the plug chop the main is good to go...I assume its the needle or could it be a combination of both. I have pics of plugs if u need to see them. Thanks what is your current jetting? Quote Link to comment Share on other sites More sharing options...
blubyyou Posted July 12, 2011 Author Report Share Posted July 12, 2011 148 mains, 48 pilot, CEL needle in middle position @ 2400 feet. I just raised the clip up a notch and the plugs do look drier just playing around in the yard. I haven't got to get a good 1-6 pull and another chop. Just wondering what direction to head in. Thanks. Quote Link to comment Share on other sites More sharing options...
