bansman76 Posted July 2, 2011 Report Share Posted July 2, 2011 left side footpeg bolts are stripped.. whats the best and quickest way to fix? (would like to ride tomorrow) doesw the rear bolt holes go alll the way thru frame ? Quote Link to comment Share on other sites More sharing options...
Big Bucks Posted July 2, 2011 Report Share Posted July 2, 2011 left side footpeg bolts are stripped.. whats the best and quickest way to fix? (would like to ride tomorrow) doesw the rear bolt holes go alll the way thru frame ? yes it does Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted July 2, 2011 Report Share Posted July 2, 2011 tape the holes out for the next size up, thats what i did on mine when they stripped Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 2, 2011 Report Share Posted July 2, 2011 You can use a piece of all thread on the rear bolt. I used 3/8" or 7/16" one time. Just ran it all the way through and put a bolt on either side. This is probably the best fix for it as the stock setup is just a nut welded onto the inside of the round piece you put the foot peg up against. Quote Link to comment Share on other sites More sharing options...
bansman76 Posted July 3, 2011 Author Report Share Posted July 3, 2011 thanks guys for the advice..tapped it out to bigger size today and seems to work fine..i think i willgo on and all thread the back bolts just so it wont happen again Quote Link to comment Share on other sites More sharing options...
