Need help with clutch
I have a dynoed 94 hp banshee my problem is what clutch do you guys run? I go thru them like coffee goes thru my body.
Is there a clutch that I can get that won't slip and that I can pull in without a gym membership? This is not an all out drag bike and I do not have an over ride tranny.
Thanks for any help! Jim
I have never rode a bike with a lock out but was told that at high rpm that it is very hard to pull the clutch in to shift.
I was looking for what brand you guys are running. I have tried a few and was wonder what brand you have had the best luck with.
Thanks jim
just remember that if your going to be buying a lock-out then your going to need to buy a lockout cover as they will not fit under the stock clutch cover.......however there is one that will and its called the slingshot. it uses ball bearings as the weights to increase or decrease the holding force (you can adjust the clmaping force by adding or subtracting ball bearings) You should be able to shift during high rev situations......it may be just barely harder to pull the clutch....but not a big problem...
